Hi. I’m Mingu.
I try control gpio of jetson tx2 using C++ code.
Now, My code can control the gpio. But it needs the sudo command for root permission.
How can I use gpio without root permission?
Hi. I’m Mingu.
hello mk.kang,
suppose you’re have implementation as below steps to control gpio.
Generate gpioXXX name
$ echo XXX > export
Enable the gpio
$ cd gpioXXX
$ echo out > direction && echo 1 > value
you might also check below sources, there’re general APIs to control gpio pin.
<i>$l4t-r32.2/kernel_src/kernel/kernel-4.9/include/linux/gpio.h</i>
static inline int gpio_get_value(unsigned int gpio)
return __gpio_get_value(gpio);
static inline void gpio_set_value(unsigned int gpio, int value)
__gpio_set_value(gpio, value);
in addition, please also check the kernel driver for the reference to control GPIO
<i>$l4t-r32.2/kernel_src/kernel/nvidia/drivers/media/i2c/imx185.c</i>
if (pw->reset_gpio) {
gpio_set_value(pw->reset_gpio, 0);
Below is part of the code I am using.
int gpioExport ( jetsonGPIO gpio )
int fileDescriptor, length;
char commandBuffer[MAX_BUF];
fileDescriptor = open("/sys/class/gpio/export", O_WRONLY);
if (fileDescriptor < 0) {
char errorBuffer[128] ;
snprintf(errorBuffer,sizeof(errorBuffer), "gpioExport unable to open gpio%d",gpio) ;
perror(errorBuffer);
return fileDescriptor;
length = snprintf(commandBuffer, sizeof(commandBuffer), "%d", gpio);
if (write(fileDescriptor, commandBuffer, length) != length) {
perror("gpioExport");
return fileDescriptor ;
close(fileDescriptor);
return 0;
For access the file’/sys/class/gpio/export’, i needs the root permission.
But i want to use gpio without root permission.
hello mk.kang,
yap, you’ll need root permission to access sysnodes.
you may check the APIs in comment #2 to implement low-level drivers to control GPIOs.
thanks
hello JerryChang.
I understand your answer.
To check low-level drivers to control GPIOs, Where can I find some examples or documentation?
that’s also in comment #2, please also check the kernel driver for the reference to control GPIO
