Hi everyone,
I use TX2 module intalled JetPack 4.6. I use mbw test memory bandwidth, the bandwidth has dropped. The mbw source code GitHub - raas/mbw: Memory Bandwidth Benchmark
Before I test I maximize the performance first
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
TX2 intall JetPack 4.3 test result
./mbw -q -n 10 256
AVG Method: MEMCPY Elapsed: 0.03210 MiB: 256.00000 Copy: 7975.277 MiB/s
AVG Method: DUMB Elapsed: 0.05566 MiB: 256.00000 Copy: 4599.535 MiB/s
AVG Method: MCBLOCK Elapsed: 0.04334 MiB: 256.00000 Copy: 5906.456 MiB/s
TX2 intall JetPack 4.6test result
./mbw -q -n 10 256
AVG Method: MEMCPY Elapsed: 0.06929 MiB: 256.00000 Copy: 3694.862 MiB/s
AVG Method: DUMB Elapsed: 0.26994 MiB: 256.00000 Copy: 948.359 MiB/s
AVG Method: MCBLOCK Elapsed: 0.06397 MiB: 256.00000 Copy: 4002.139 MiB/s
When testing I check the EMC_FREQ as below
$ sudo tegrastats
RAM 1552/7860MB (lfb 1287x4MB) SWAP 0/3930MB (cached 0MB) CPU [100%@2035,0%@2035,0%@2035,0%@2049,0%@2054,0%@2035] EMC_FREQ 14%@1866 GR3D_FREQ 0%@1300 APE 150 MTS fg 0% bg 0% PLL@46C MCPU@46C PMIC@50C Tboard@41C GPU@44.5C BCPU@46C thermal@45.4C Tdiode@44.75C VDD_SYS_GPU 228/228 VDD_SYS_SOC 1068/1035 VDD_4V0_WIFI 0/0 VDD_IN 5268/4994 VDD_SYS_CPU 1221/1100 VDD_SYS_DDR 1692/1608
What’s diffrence between JetPack 4.6 and JetPack 4.3? Thanks.
