I have two deep network structure, both using TensorRT and having IPlugins in them. They were working well when I was using Jetpack 3.1 on TX2. I have upgraded it to Jetpack 3.3 without installing Opencv and Visionworks, and then installed OpenCV3.4(It is unrelated to the networks but needed for my project). Now one of the networks working well again, but the other one returns error during buildCudaEngine method of TensorRT. Details of the error shown below:
[GIE] Original: 29 layers
[GIE] After dead-layer removal: 29 layers
[GIE] After scale fusion: 29 layers
[GIE] Fusing fc6-1 with relu6
[GIE] Fusing fc7 with relu7
[GIE] After vertical fusions: 27 layers
[GIE] After swap: 27 layers
[GIE] After final dead-layer removal: 27 layers
[GIE] After tensor merging: 27 layers
[GIE] After concat removal: 27 layers
[GIE] Graph costruction and optimization completed in 0.00105677 seconds.
[GIE] cudnnEngine.cpp (87) - Cuda Error in initializeCommonContext: 4 (Could not initialize cudnn, please check cudnn installation.)
[GIE] failed to build CUDA engine
I don’t know whether this is a problem of TensorRT or cuDNN or TX2, but I post it here.
I would appreciate any help if anyone knows whether there is a solution to this or the meaning and reason of the error so that I can check stuffs on my code.
Thanks in advance.
