Hi all,
After configuring CUDA and TensorRT, I have compiled sample successfully. However, when I run it, it returns …
ERROR: cudnnEngine.cpp (55) - Cuda Error in initializeCommonContext: 4
sample_mnist: sampleMNIST.cpp:63: void caffeToGIEModel(const string&, const string&, const std::vector<std::basic_string<char> >&, unsigned int, nvinfer1::IHostMemory*&): Assertion `engine' failed.
And the relative codes are
void caffeToGIEModel(const std::string& deployFile, // name for caffe prototxt
const std::string& modelFile, // name for model
const std::vector<std::string>& outputs, // network outputs
unsigned int maxBatchSize, // batch size - NB must be at least as large as the batch we want to run with)
IHostMemory *&gieModelStream) // output buffer for the GIE model
// create the builder
IBuilder* builder = createInferBuilder(gLogger);
// parse the caffe model to populate the network, then set the outputs
INetworkDefinition* network = builder->createNetwork();
ICaffeParser* parser = createCaffeParser();
const IBlobNameToTensor* blobNameToTensor = parser->parse(locateFile(deployFile, directories).c_str(),
locateFile(modelFile, directories).c_str(),
*network,
DataType::kFLOAT);
// specify which tensors are outputs
for (auto& s : outputs)
network->markOutput(*blobNameToTensor->find(s.c_str()));
// Build the engine
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(1 << 20);
ICudaEngine* engine = builder->buildCudaEngine(*network);
assert(engine);
// we don't need the network any more, and we can destroy the parser
network->destroy();
parser->destroy();
// serialize the engine, then close everything down
gieModelStream = engine->serialize();
engine->destroy();
builder->destroy();
shutdownProtobufLibrary();
Since it’s about cudnnEngine, so is there any problem with my cuDNN?
I installed cuDNN by copying files to /usr/local/cuda/.
tar -xzvf cudnn-8.0-linux-x64-v7.tgz
sudo cp cuda/include/cudnn.h /usr/local/cuda/include
sudo cp cuda/lib64/libcudnn* /usr/local/cuda/lib64
sudo chmod a+r /usr/local/cuda/include/cudnn.h
/usr/local/cuda/lib64/libcudnn*
