Hi guys, sample codes provided with the TensorRT are failing to “Cuda Error in initializeCommonContext”,
root@7bd0146a7877:/usr/src/tensorrt/bin# ./sample_uff_mnist
…/data/mnist/lenet5.uff
ERROR: cudnnEngine.cpp (56) - Cuda Error in initializeCommonContext: 1
ERROR: sample_uff_mnist: Unable to create engine
ERROR: sample_uff_mnist: Model load failed
I use docker which contains cuda-8.0, cudnn7. Nvidia driver info is
root@7bd0146a7877:/usr/src/tensorrt/bin# nvidia-smi
Fri Dec 29 04:45:31 2017
| NVIDIA-SMI 375.66 Driver Version: 375.66 |
| 0 GeForce GTX 1080 Off | 0000:04:00.0 Off | N/A |
| 27% 35C P8 9W / 180W | 2MiB / 8114MiB | 0% Default |
| 1 GeForce GTX 1080 Off | 0000:05:00.0 Off | N/A |
| 27% 37C P8 11W / 180W | 2MiB / 8114MiB | 0% Default |
| 2 GeForce GTX 1080 Off | 0000:08:00.0 Off | N/A |
| 27% 37C P8 9W / 180W | 2MiB / 8114MiB | 0% Default |
| 3 GeForce GTX 1080 Off | 0000:09:00.0 Off | N/A |
| 27% 38C P8 9W / 180W | 2MiB / 8114MiB | 0% Default |
| 4 GeForce GTX 1080 Off | 0000:83:00.0 Off | N/A |
| 27% 36C P8 10W / 180W | 2MiB / 8114MiB | 0% Default |
| 5 GeForce GTX 1080 Off | 0000:84:00.0 Off | N/A |
| 27% 35C P8 10W / 180W | 2MiB / 8114MiB | 0% Default |
| 6 GeForce GTX 1080 Off | 0000:87:00.0 Off | N/A |
| 27% 34C P8 10W / 180W | 2MiB / 8114MiB | 0% Default |
| 7 GeForce GTX 1080 Off | 0000:88:00.0 Off | N/A |
| 54% 82C P2 142W / 180W | 1565MiB / 8114MiB | 75% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
Could anyone share some solutions? Thanks very much.
