TX2 mmc2 error reboot
[ 1881.534584] mmc2: Data CRC error
[ 1881.537821] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 1881.543647] sdhci: Sys addr: 0x00000400 | Version: 0x00000404
[ 1881.549473] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000175
[ 1881.555299] sdhci: Argument: 0x008a6800 | Trn mode: 0x0000002b
[ 1881.561124] sdhci: Present: 0x01fb0008 | Host ctl: 0x00000017
[ 1881.566948] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 1881.572771] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 1881.578594] sdhci: Timeout: 0x0000000d | Int stat: 0x00001000
[ 1881.584419] sdhci: Int enab: 0x02ff108b | Sig enab: 0x02fc108b
[ 1881.590243] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 1881.596066] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 1881.601889] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 1881.607712] sdhci: Host ctl2: 0x0000308b
[ 1881.611629] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe470
[ 1881.618165] sdhci: ===========================================
[ 1902.876280] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 1902.881960] 0-…: (2 GPs behind) idle=d7d/2/0 softirq=303644/303645 fqs=2474
[ 1902.889257] (detected by 4, t=5252 jiffies, g=144556, c=144555, q=10187)
[ 1903.036280] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1903.041777] 0-…: (1 GPs behind) idle=d7d/2/0 softirq=303560/303645 fqs=2476
[ 1903.049074] (detected by 5, t=5255 jiffies, g=8883, c=8882, q=186)
[ 1908.172301] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 23s! [swapper/0:0]
[ 1908.179716] Kernel panic - not syncing: softlockup: hung tasks
[ 1908.185542] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G L 4.9.140-tegra #1
[ 1908.193273] Hardware name: quill (DT)
[ 1908.196929] Call trace:
[ 1908.199373] [] dump_backtrace+0x0/0x198
[ 1908.204764] [] show_stack+0x24/0x30
[ 1908.209809] [] dump_stack+0x98/0xc0
[ 1908.214854] [] panic+0x11c/0x298
[ 1908.219638] [] watchdog_unpark_threads+0x0/0x98
[ 1908.225723] [] __hrtimer_run_queues+0xd8/0x360
[ 1908.231719] [] hrtimer_interrupt+0xa8/0x1e0
[ 1908.237457] [] tegra186_timer_isr+0x34/0x48
[ 1908.243196] [] __handle_irq_event_percpu+0x68/0x288
[ 1908.249626] [] handle_irq_event_percpu+0x28/0x60
[ 1908.255795] [] handle_irq_event+0x50/0x80
[ 1908.261359] [] handle_fasteoi_irq+0xc8/0x1b8
[ 1908.267182] [] generic_handle_irq+0x34/0x50
[ 1908.272918] [] __handle_domain_irq+0x68/0xc0
[ 1908.278741] [] gic_handle_irq+0x5c/0xb0
[ 1908.284129] [] el1_irq+0xe8/0x18c
[ 1908.289000] [] irq_exit+0xd0/0x118
[ 1908.293956] [] __handle_domain_irq+0x6c/0xc0
[ 1908.299779] [] gic_handle_irq+0x5c/0xb0
[ 1908.305168] [] el1_irq+0xe8/0x18c
[ 1908.310040] [] cpuidle_enter_state+0xb8/0x380
[ 1908.315950] [] cpuidle_enter+0x34/0x48
[ 1908.321254] [] call_cpuidle+0x44/0x70
[ 1908.326470] [] cpu_startup_entry+0x1b0/0x200
[ 1908.332295] [] rest_init+0x84/0x90
[ 1908.337254] [] start_kernel+0x370/0x384
[ 1908.342643] [] __primary_switched+0x80/0x94
[ 1908.348381] SMP: stopping secondary CPUs
[ 1908.352326] Kernel Offset: disabled
[ 1908.355806] Memory Limit: none
[ 1908.358855] trusty-log panic notifier - trusty version Built: 21:16:26 Jun 25 2020 [ 1908.372661] Rebooting in 5 seconds…
Is this custom board or TX2 developer kit?
RTIMES board, and use their method
Please check with them since we don’t know details about their board design.
