Hello all.
We are trying to get an IMX219 CSI camera running inside a docker container.
The docker container will be deployed on Balena, and it will not have nvidia runtime, so all the dependencies need to be installed within the container.
This is the dockerfile that we have used successfully in the Nano. I used this one as a template:
FROM balenalib/jetson-nano-ubuntu-node:14-bionic as buildstep
WORKDIR /usr/src/app
# Don't prompt with any configuration questions
ENV DEBIAN_FRONTEND noninteractive
# Download and install BSP binaries for L4T 32.5.1
RUN apt-get update && apt-get install -y wget tar lbzip2 python3 libegl1 binutils && \
wget https://developer.nvidia.com/embedded/l4t/r32_release_v5.2/t210/jetson-210_linux_r32.5.2_aarch64.tbz2 && \
tar xf jetson-210_linux_r32.5.2_aarch64.tbz2 && \
cd Linux_for_Tegra && \
sed -i 's/config.tbz2\"/config.tbz2\" --exclude=etc\/hosts --exclude=etc\/hostname/g' apply_binaries.sh && \
sed -i 's/install --owner=root --group=root \"${QEMU_BIN}\" \"${L4T_ROOTFS_DIR}\/usr\/bin\/\"/#install --owner=root --group=root \"${QEMU_BIN}\" \"${L4T_ROOTFS_DIR}\/usr\/bin\/\"/g' nv_tegra/nv-apply-debs.sh && \
sed -i 's/LC_ALL=C chroot . mount -t proc none \/proc/ /g' nv_tegra/nv-apply-debs.sh && \
sed -i 's/umount ${L4T_ROOTFS_DIR}\/proc/ /g' nv_tegra/nv-apply-debs.sh && \
sed -i 's/chroot . \// /g' nv_tegra/nv-apply-debs.sh && \
./apply_binaries.sh -r / --target-overlay && cd .. \
rm -rf jetson-210_linux_r32.5.2_aarch64.tbz2 && \
rm -rf Linux_for_Tegra && \
echo "/usr/lib/aarch64-linux-gnu/tegra" > /etc/ld.so.conf.d/nvidia-tegra.conf && \
echo "/usr/lib/aarch64-linux-gnu/tegra-egl" >> /etc/ld.so.conf.d/nvidia-tegra.conf && \
ldconfig
# Install CUDA, CUDA compiler and some utilities
RUN \
apt-get update && apt-get install -y cuda-toolkit-10-2 cuda-compiler-10-2 \
lbzip2 xorg-dev \
cmake wget unzip \
libgtk2.0-dev \
libavcodec-dev \
libgstreamer1.0-dev \
libgstreamer-plugins-base1.0-dev \
libjpeg-dev \
libpng-dev \
libtiff-dev \
libdc1394-22-dev -y --no-install-recommends && \
wget https://github.com/opencv/opencv/archive/4.0.1.zip && \
unzip 4.0.1.zip && rm 4.0.1.zip
# COPY ./build-resources/4.0.1-contrib.zip ./opencv_modules.4.0.1.zip
RUN \
wget https://github.com/opencv/opencv_contrib/archive/4.0.1.zip -O opencv_modules.4.0.1.zip && \
unzip opencv_modules.4.0.1.zip && rm opencv_modules.4.0.1.zip && \
export CUDA_HOME=/usr/local/cuda-10.2/ && \
export LD_LIBRARY_PATH=${CUDA_HOME}/lib64 && \
PATH=${CUDA_HOME}/bin:${PATH} && export PATH && \
mkdir -p opencv-4.0.1/build && cd opencv-4.0.1/build && \
cmake -D WITH_CUDA=ON -D CUDA_ARCH_BIN="5.3" -D BUILD_LIST=cudev,highgui,videoio,cudaimgproc,ximgproc -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-4.0.1/modules -D CUDA_ARCH_PTX="" -D WITH_GSTREAMER=ON -D WITH_LIBV4L=ON -D BUILD_TESTS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_SAMPLES=OFF -D BUILD_EXAMPLES=OFF -D CMAKE_BUILD_TYPE=RELEASE -D WITH_GTK=ON -D BUILD_DOCS=OFF -D CMAKE_INSTALL_PREFIX=/usr/local .. && \
make -j32 && make install && \
cp /usr/src/app/opencv-4.0.1/build/bin/opencv_version /usr/src/app/ && \
rm -rf /usr/src/app/opencv-4.0.1 && \
rm -rf /usr/src/app/opencv_contrib-4.0.1
ENV UDEV=1
ENV LD_LIBRARY_PATH=/usr/local/lib
# Install G-Streamer
#https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/accelerated_gstreamer.html#wwpID0E0R40HA
RUN apt-get update && apt-get install -y gstreamer1.0-tools gstreamer1.0-alsa \
gstreamer1.0-plugins-base gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly \
gstreamer1.0-libav
RUN apt-get install -y libgstreamer1.0-dev \
libgstreamer-plugins-good1.0-dev \
libgstreamer-plugins-bad1.0-dev
CMD [ "sleep", "infinity" ]
When running the container, I’m running it as privileged with cap_add SYS_RAWIO (though i’m not sure if required).
Inside the container I run nvargus-daemon & and then try to launch gstreamer. I’m getting a whole bunch of gstreamer errors that I have no idea how to address.
root@voltera-desktop:/# gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: Connection refused (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 201)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 102)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:639 Failed to create CameraProvider
(gst-launch-1.0:224): GStreamer-CRITICAL **: 17:17:04.100: gst_mini_object_set_qdata: assertion 'object != NULL' failed
Got EOS from element "pipeline0".
Execution ended after 0:00:00.001363826
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
root@voltera-desktop:/# nvargus-daemon &
[1] 235
root@voltera-desktop:/# === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
=== gst-launch-1.0[240]: Connection established (7F7239C1D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
NvPclHwGetModuleList: No module data found
NvPclHwScanExternalCameras: Failed to stat '/dev//log'; No such file or directory
NvPclHwScanExternalCameras: Failed to stat '/dev//initctl'; No such file or directory
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
(gst-launch-1.0:240): GStreamer-CRITICAL **: 17:17:18.539: gst_mini_object_set_qdata: assertion 'object != NULL' failed
Execution ended after 0:00:00.626490142
Like I mentioned, this seemed to work on the Nano. Any guidance would be appreciated.
