I have test video compress performance of TX1 and TX2, but result show TX2 more weaker than TX1
first TX1
gst-launch-1.0 nvcamerasrc num-buffers=1800 ! 'video/x-raw(memory:NVMM), format=(string)I420, width=(int)4096, height=(int)3076, framerate=(fraction)30/1' ! nvvidconv ! 'video/x-raw, format=(string)I420, width=(int)4096, height=(int)3076, framerate=(fraction)30/1' ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420, width=(int)4096, height=(int)2048, framerate=(fraction)30/1' ! omxh264enc ! splitmuxsink async-handling=true location=test%d.mp4 max-size-time=60000000000
it take 1 min
(gst-plugin-scanner:1982): GLib-GObject-WARNING **: cannot register existing type 'GstBaseTextOverlay'
(gst-plugin-scanner:1982): GLib-CRITICAL **: g_once_init_leave: assertion 'result != 0' failed
(gst-plugin-scanner:1982): GLib-GObject-CRITICAL **: g_type_register_static: assertion 'parent_type > 0' failed
(gst-plugin-scanner:1982): GStreamer-CRITICAL **: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed
Setting pipeline to PAUSED ...
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and Mjstreaming
Available Sensor modes :
2592 x 1944 FR=30.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
2592 x 1458 FR=30.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
1280 x 720 FR=120.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
Pipeline is live and does not need PREROLL ...
NvCameraSrc: Trying To Set Default Camera Resolution. Selected 4096x3076 FrameRate = 30.000000 ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
===== MSENC blits (mode: 1) into tiled surfaces =====
Got EOS from element "pipeline0".
Execution ended after 0:01:00.201738883
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
next is TX2
but TX2 take 3 min 19s
2592 x 1944 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
2592 x 1458 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
1280 x 720 FR=120.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 0 WxH = 2592x1944 FrameRate = 30.000000 ...
===== MSENC =====
Execution ended after 0:03:19.815397458
Hi, can you try with 2592 x 1944? The max resolution of onboard 5693 is 2592x1944, not 4K.
but i use videotestsrc on TX2 also take 1 min 42s
gst-launch-1.0 videotestsrc num-buffers=1800 ! queue ! 'video/x-raw, format=(string)I420, width=(int)4096, height=(int)2048, framerate=(fraction)30/1' ! omxh264enc ! qtmux ! filesink location=test.mp4
Pipeline is PREROLLING ...
===== MSENC =====
Pipeline is PREROLLED ...
Execution ended after 0:01:42.523451707
i use TX2 module on board of TX1, is it will influence performance of TX2 ?
Hi gunagjie,
videotestsrc is a CPU-buffer source. The best performance needs NVMM-buffer source like nvcamerasrc.
i test nvcamerasrc can supply 4k@30fps video raw data
gst-launch-1.0 nvcamerasrc num-buffers=1800 ! 'video/x-raw(memory:NVMM), format=(string)I420, width=(int)4096, height=(int)2048, framerate=(fraction)30/1' ! nvvidconv ! fakesink
Execution ended after 0:01:00.165139928
but when i compress video, it take 1 min 7s
gst-launch-1.0 nvcamerasrc num-buffers=1800 ! 'video/x-raw(memory:NVMM), format=(string)I420, width=(int)4096, height=(int)2048, framerate=(fraction)30/1' ! omxh264enc ! fakesink
===== MSENC =====
Execution ended after 0:01:07.097884661
Hi gunagjie,
Available sensor modes show you are using onboard ov5693, which does not have 4K…
how can i test 4K@30fps performance ?
hello gunagjie,
you could contact NV partners for 4k@30 bayer sensors.
[url]https://developer.nvidia.com/embedded/community/partners[/url]
