Hi All,
I found a strange U-BOOT failure.
Hope, someone knows what it is.
It happened after couple month of development work on unit.
Reflashing by JetPack does not help.
Sometimes it boots successfully.
Pressing a key to interrupt autoboot and typing boot after helps every time.
Please look at the line 120:
[0000.187] [TegraBoot] (version 23.00.2015.14-mobile-3a15407d)
[0000.193] Processing in cold boot mode Bootloader 2
[0000.197] A01 Bootrom Patch rev = 63
[0000.201] Power-up reason: reset button
[0000.204] No Battery Present
[0000.207] Platform has Ddr4 type ram
[0000.211] max77620 disabling SD1 Remote Sense
[0000.215] Setting Ddr voltage to 1125mv
[0000.219] Serial Number of Pmic Max77663: 0xa0ce1
[0000.227] Entering ramdump check
[0000.230] Get RamDumpCarveOut = 0x0
[0000.233] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.238] Last reboot was clean, booting normally!
[0000.243] Sdram initialization is successful
[0000.247] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.252] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.278] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.304] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.309] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.314] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.320] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.325] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.340] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.346] Platform-DebugCarveout: 0
[0000.349] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.399] Using GPT Primary to query partitions
[0000.405] Loading Tboot-CPU binary
[0000.454] Verifying bootloader in OdmNonSecureSBK mode
[0000.463] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.473] Bootloader downloaded successfully.
[0000.477] Downloaded Tboot-CPU binary to 0xa0000258
[0000.482] MAX77620_GPIO1 Configured.
[0000.486] MAX77620_GPIO5 Configured.
[0000.489] CPU power rail is up
[0000.492] CPU clock enabled
[0000.496] Performing RAM repair
[0000.499] Updating A64 Warmreset Address to 0xa00002e9
[0000.516] Bootloader DTB Load Address: 0x83000000
[0000.533] Kernel DTB Load Address: 0x83080000
[0000.538] Loading cboot binary
[0000.631] Verifying bootloader in OdmNonSecureSBK mode
[0000.725] Bootloader load address is 0x8010fda8, entry address is 0x80110000
[0000.734] Bootloader downloaded successfully.
[0000.738] GPT: Partition NOT found !
[0000.742] Find Partition via GPT Failed
[0000.745] function NvTbootGetBinaryOffsets: 0x845208 error
[0000.750] Error in NvTbootLoadBinary: 0x845208 !
[0000.755] Next binary entry address: 0x80110000
[0000.759] BoardId: 2180
[0000.786] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0000.793] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0000.802] NvTbootI2c: Read failed for slave 0xa2, offset 0x00 with error code 0x00045001
[0000.810] Display board id read failed
[0000.814] dram memory type is 3
[0000.817] WB0 init successful
[0000.844] Bpmp FW successfully loaded
[0000.847] Set NvDecSticky Bits
[0000.850] GSC1 address : ff700000
[0000.854] GSC2 address : ff600000
[0000.858] GSC3 address : ff500000
[0000.862] GSC4 address : ff400000
[0000.865] GSC5 address : ff300000
[0000.868] GSC MC Settings done
[0000.872] TOS old plaintext Image length 61440
[0000.878] *** Secure OS image signature not verified ***
[0000.883] Loading and Validation of Secure OS Successful
[0000.888] NvTbootPackSdramParams: start.
[0000.894] NvTbootPackSdramParams: done.
[0000.897] Tegraboot started after 166928 us
[0000.901] Basic modules init took 349622 us
[0000.905] Sec Bootdevice Read Time = 194 ms, Read Size = 8459 KB
[0000.911] Next stage binary read took 12266 us
[0000.915] Carveout took 251650 us
[0000.918] CPU initialization took 138810 us
[0000.922] Total time taken by TegraBoot 752348 us
[0000.927] Starting CPU & Halting co-processor
64b[0001.063] LPDDR4 Training: Number of tables = 10
[0001.067] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.073] EMC Training Successful
[0001.076] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.082] EMC Training Successful
[0001.085] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.096] EMC Training Successful
[0001.099] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.122] EMC Training Successful
[0001.125] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.147] EMC Training Successful
[0001.150] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.169] EMC Training Successful
[0001.173] Switching to 800000 KHz Success
[0001.206] LPDDR4 Training: Number of tables = 10
U-Boot 2015.07-rc2-geea3f71 (Feb 08 2016 - 17:37:49 -0800)
TEGRA210
Model: NVIDIA P2371-2180
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x0000000012000000-0x0000000012010000
tegra-pcie: non-prefetchable memory: 0x0000000013000000-0x0000000020000000
tegra-pcie: prefetchable memory: 0x0000000020000000-0x0000000040000000
tegra-pcie: 4x1, 1x1 configuration
tegra-pcie: probing port 0, using 4 lanes
tegra-pcie: probing port 1, using 1 lanes
tegra-pcie: link 1 down, retrying
tegra-pcie: link 1 down, ignoring
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
Tegra210 (P2371-2180) # 2.479470] usb-vbus1: 5000 mV ; R[ 2.509249] en-mdm-pwr-3v7: ; Rail OFF
Unknown command '2.479470]' - try 'help'
Unknown command 'R[' - try 'help'
Unknown command 'Rail' - try 'help'
Tegra210 (P2371-2180) # [ 2.513136] en-vdd-disp-1v8: 1800 mV ; Rail ON
Unknown command '[' - try 'help'
Tegra210 (P2371-2180) # [ 2.517392] en-vdd-cam-hv-2v8: ; Rail OFF
Tegra210 (P2371-2180) # [ 2.521114] rtl-5v0: ; Rail OFF
Tegra210 (P2371-2180) # [ 2.524192] en-usb-vbus2: ; Rail OFF
Tegra210 (P2371-2180) # [ 2.528071] en-vdd-cam-1v2: ; Rail OFF
Tegra210 (P2371-2180) # [ 2.532163] regulator-pwm 0.pwm-regulator: PWM request deferred
