There are 2 UARTS ports on Xavier Jetson NX. It 4-wire design.
And I would like know that the behavior of TX and RTS.
As I know TX is low active when data transmitted.
If you enabled UART function, which RTS behavior is yours? ( I means correct one)
Is upper one waveform or lower one waveform?
I measure our RTS signal on UART0 and UART1, it always be high.
So I think there are something wrong in software setting.
Therefore, I will check the FW setting with you step by step.
By the way, I’m not a software side engineer, so if possible, please kindly describe it more detail to let me know how to adjust.
I will post any software setting , and I wish I can get the same behvior with yours after this discussion finished.
This step I want to check the GPIO table is correct or not.
Here are my current setting. Should something be modified?
Hi allison_chen,
Are you using the devkit or custom board for Xavier NX?
If you want to use hw flow control for UART, you should enable the either flag as following:
Could you share the block diagram of connection?
It seems you are using uartb@3110000 to communicate with the UART device.
What UART device are you using?
