Trying to use the Jetson Orin Nano, with JP6, in a devkit with uarta serial@3100000
I’ve seen the other topics that claim ttyTHS means the uart is running in DMA mode, but I checked the drivers, and they will revert to PIO mode when the dma settings are not included in the dtsi.
The /var/log/dmesg shows the output RX and TX in PIO by default after flashing.
[ 3.583791] kernel: gpio-394 (camera-control-output-low): hogged as output/low
[ 3.588464] kernel: tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.590027] kernel: tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 3.591731] kernel: serial-tegra 3100000.serial: RX in PIO mode
[ 3.591736] kernel: serial-tegra 3100000.serial: TX in PIO mode
[ 3.591805] kernel: 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.592917] kernel: serial-tegra 3140000.serial: RX in PIO mode
[ 3.592921] kernel: serial-tegra 3140000.serial: TX in PIO mode
[ 3.592965] kernel: 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
In fact, none of the serials have the dma names or dma values in the ./source/hardware/nvidia/t23x/nv-public/tegra234.dtsi (or any other overlay I can find):
uarta: serial@3100000 {
compatible = "nvidia,tegra234-uart", "nvidia,tegra20-uart";
reg = <0x0 0x03100000 0x0 0x10000>;
interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&bpmp TEGRA234_CLK_UARTA>;
resets = <&bpmp TEGRA234_RESET_UARTA>;
I have tried to look at the TRM, and see uarta should be requestor 8, so I made an overlay and applied it:
/dts-v1/;
/plugin/;
fragment@0 {
target-path="/bus@0/serial@3100000";
__overlay__ {
dmas = <&gpcdma 8>;
dma-names= "rx";
status = "okay";
After the overlay, the log correctly shows that only the TX is in PIO mode:
[ 1.749629] kernel: tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 1.752081] kernel: serial-tegra 3100000.serial: TX in PIO mode
[ 1.752223] kernel: 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
However, trying to read anything fails at any speeds with VPR and context violations:
[ 280.749235] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240000, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.749389] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240000, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.749531] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240000, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.749671] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240000, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.749811] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240000, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.749951] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240000, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.750091] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240040, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.750231] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240040, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.750370] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240040, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.750506] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x402, iova=0x80240040, fsynr=0xf0011, cbfrsynra=0xc04, cb=0
[ 280.751564] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 281.894265] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 282.425979] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 282.577129] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 283.404896] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 283.407241] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 283.411772] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 283.414054] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 283.416328] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
[ 283.420859] tegra-mc 2c00000.memory-controller: unknown: secure write @0x00000003ffffff00: VPR violation ((null))
Can someone please help provide the proper way to configure UARTA for DMA? Only RX is fine, but I can’t seem to get it to work reliably.
