Hi
I’d like to boot up UEFI logo carrying over kernel.
boot up → UEFI logo → carry over kernel
How could I do it?
Thank you
Hi
How could I do it?
Thank you
To boot up with a UEFI logo carrying over to the kernel boot up on a Jetson Orin Nano, you’ll need to modify the UEFI bootloader and kernel configuration. Here’s a step-by-step guide to help you achieve this:
Prerequisites:
Step 1: Modify the UEFI bootloader
uefi_jetson.bin binary file to flash the miniUEFI to the Jetson AGX Orin. This will update the UEFI bootloader.miniUEFI binary file generated by the miniUEFI tool to flash the UEFI bootloader.Step 2: Configure the UEFI bootloader to display a logo
oem-config tool to configure the UEFI bootloader to display a logo during boot-up. You can specify the logo image file and its location using the oem-config tool.Step 3: Modify the kernel configuration
Toolchain to compile and build the modified kernel.Step 4: Update the kernel and dtb with bootloader secureboot and uefi secureboot
Step 5: Verify the UEFI logo display during boot-up
Comparison with other Jetson devices:
The process outlined above is specific to the Jetson Orin Nano. However, the general steps can be applied to other Jetson devices, such as the Jetson AGX Orin or Jetson Nano 2GB, with some modifications to the UEFI bootloader and kernel configuration.
Additional resources:
By following these steps, you should be able to boot up with a UEFI logo carrying over to the kernel boot up on your Jetson Orin Nano.
Hi
Could you tell me what I have to to do each step in detail ?
Thank you
Hi sw0128,
Are you using the devkit or custom board for Orin Nano?
What do you mean about “carrying over kernel”?
Show boot logo from UEFI stage until kernel boot (before entering desktop)?
Hi
=> custom board for Orin Nano
=> JetPack6.2.1
=> I know I can see boot logos - NVIDIA two times with JetPack6.2.1
I want the the first NVIDIA boot logo keeps until the second NVIDIA boot logo.
Thank you
Hi
I solved it!
Thank you for your great help!!!
Thanks ~0813
As my understanding, they are from different boot stage and both bootloader(UEFI) and kernel should initialize them seperately?
Could you share how do you solve them for “the first NVIDIA boot logo keeps until the second NVIDIA boot logo”?
