nvidia: building from workspace rooted at: /home/qi/jet-pack-5.0.2/src/bootloader/uefi
nvidia: found command: python3.
nvidia: found command: virtualenv.
nvidia: found command: mono.
nvidia: found command: aarch64-linux-gnu-gcc.
nvidia: Activating Python virtual environment.
nvidia: Building from tarball
nvidia: Updating build environment (edk2-nvidia/Platform/NVIDIA/Jetson/PlatformBuild.py).
SECTION - Init SDE
SECTION - Loading Plugins
SECTION - Start Invocable Tool
SECTION - Initial update of environment
Updating. Done
SECTION - Updated/Verified 2 dependencies
SECTION - Second pass update of environment
Updating. Done
SECTION - Summary
PROGRESS - Success
nvidia: Building basetools.
SECTION - Init SDE
File “edk2/BaseTools/Edk2ToolsBuild.py”, line 177, in
main()
File “edk2/BaseTools/Edk2ToolsBuild.py”, line 173, in main
Edk2ToolsBuild().Invoke()
File “/home/qi/jet-pack-5.0.2/src/bootloader/uefi/venv/lib/python3.8/site-packages/edk2toolext/base_abstract_invocable.py”, line 146, in Invoke
retcode = self.Go()
File “edk2/BaseTools/Edk2ToolsBuild.py”, line 148, in Go
raise Exception(“Failed to build.”)
Exception: Failed to build.
My pc is ubuntu20.04,it can successful in ubuntu18.04
Hi Seven0,
Which Jetpack version would you like to build for uefi?
Please refer to every steps in the following instruction to build on a standalone Ubuntu host PC and let me know if there’s any issue during environment setup.
Build without docker · NVIDIA/edk2-nvidia Wiki · GitHub
