I have this trained network and I want to use it in deepstream 4.0:
Model: "model_20"
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
the_input (InputLayer) (None, 136, 68, 1) 0
conv1 (Conv2D) (None, 136, 68, 16) 160 the_input[0][0]
conv2d_1 (Conv2D) (None, 136, 68, 16) 2320 conv1[0][0]
max1 (MaxPooling2D) (None, 68, 34, 16) 0 conv2d_1[0][0]
conv2 (Conv2D) (None, 68, 34, 16) 2320 max1[0][0]
conv2d_2 (Conv2D) (None, 68, 34, 16) 2320 conv2[0][0]
max2 (MaxPooling2D) (None, 34, 17, 16) 0 conv2d_2[0][0]
reshape (Reshape) (None, 34, 272) 0 max2[0][0]
dense1 (Dense) (None, 34, 32) 8736 reshape[0][0]
gru1 (CuDNNGRU) (None, 34, 512) 838656 dense1[0][0]
gru1_b (CuDNNGRU) (None, 34, 512) 838656 dense1[0][0]
add_1 (Add) (None, 34, 512) 0 gru1[0][0]
gru1_b[0][0]
gru2 (CuDNNGRU) (None, 34, 512) 1575936 add_1[0][0]
gru2_b (CuDNNGRU) (None, 34, 512) 1575936 add_1[0][0]
concatenate_1 (Concatenate) (None, 34, 1024) 0 gru2[0][0]
gru2_b[0][0]
dense2 (Dense) (None, 34, 36) 36900 concatenate_1[0][0]
softmax (Activation) (None, 34, 36) 0 dense2[0][0]
I’ve converted it from tensorflow frozen model to UFF format:
import uff
uff.from_tensorflow_frozen_model("lpr_it0.pb",output_filename="lpr_it0.uff")
Now I want to load it into [primary-gie] with the following properties:
[property]
gpu-id=0
net-scale-factor=1
model-color-format=0
uff-file=lpr2.uff
uff-input-blob-name=the_input
output-blob-names=softmax/truediv
labelfile-path=labels-lpr.txt
network-mode=2
num-detected-classes=1
gie-unique-id=1
is-classifier=0
maintain-aspect-ratio=1
I get this error during loading:
Using winsys: x11
Creating LL OSD context new
0:00:00.805213106 13084 0x1d472840 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.195908042 13084 0x1d472840 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): UffParser: Validator error: dense2/unstack: Unsupported operation _Unpack
0:00:01.205150416 13084 0x1d472840 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Failed to parse UFF file: incorrect file or incorrect input/output blob names
0:00:01.205257448 13084 0x1d472840 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Failed to create engine from model files
0:00:01.205336147 13084 0x1d472840 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Failed to create NvDsInferContext instance
0:00:01.205369585 13084 0x1d472840 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Config file path: /opt/nvidia/deepstream/deepstream-4.0/sources/lpr/config_infer_lpr_gru.txt, NvDsInfer Error: NVDSINFER_TENSORRT_ERROR
** ERROR: <main:651>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie_classifier: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier:
App run failed
How can I fix it? Is there straighforward approach for using .pb file in DeepStream SDK?
