Would it be correct to assume that
UHP = V4L2_ENC_HW_PRESET_ULTRAFAST
HP = V4L2_ENC_HW_PRESET_FAST
HQ = V4L2_ENC_HW_PRESET_SLOW
When looking at the chart on page 15 below vs the API definitions?
Perhaps you can make the naming consistent.
hello oviano,
that linkage has moving to https://developer.nvidia.com/?filename=403.html.
may I double check which documentation you’ve point-out?
It’s the data sheet for NVIDIA Jetson Orin NX Series, your official PDF documentation.
I can’t find a link that doesn’t have that token in it, which must be specific to my login or something.
hello oviano,
I see, you’re checking [Table 2-8: Supported Video Encode Streams] from Jetson Orin NX Series Modules Data Sheet.
for instance,
HQ (High Quality), HP (High Performance), UHP (Ultra High Performance).
these modes were trade-off of throughput v.s. quality results.
assume using H264 codec, YUV420 format.
UHP support up-to 4K@60-fps; HP support up-to 4K@30-fps; HQ support up-to 1080p@60-fps.
please also refer to below specifies the encoder HW preset type.
UHP =V4L2_ENC_HW_PRESET_ULTRAFAST
HQ = V4L2_ENC_HW_PRESET_MEDIUM
enum v4l2_enc_hw_preset_type
/** Encoder HWPreset DISABLED. */
V4L2_ENC_HW_PRESET_DISABLE = 0,
/** Encoder HWPreset with per frame encode time UltraFast. */
V4L2_ENC_HW_PRESET_ULTRAFAST = 1,
/** Encoder HWPreset with per frame encode time Fast. */
V4L2_ENC_HW_PRESET_FAST,
/** Encoder HWPreset with per frame encode time Medium. */
V4L2_ENC_HW_PRESET_MEDIUM,
/** Encoder HWPreset with per frame encode time Slow. */
V4L2_ENC_HW_PRESET_SLOW,
/** Last value is Max value. */
V4L2_ENC_HW_PRESET_DEFAULT = 0x7FFFFFFF
Yes, that’s right.
Let’s say I want my encoding to support 6 x 1080p60 HEVC streams, I can see this requires “UHP” as the configuration. Does that correspond to choosing V4L2_ENC_HW_PRESET_ULTRAFAST?
hello oviano,
yes, it supports 6x 1080p@60-fps HEVC streams with UHP profile.
V4L2_ENC_HW_PRESET_ULTRAFAST is NVENC running at UHP profile, throughput at 800MP/S with HEVC.
