Could someone recommend the best solution to render dynamic overlays in video in gstreamer.
There is no existing sample. A possible solution is to access the NvBufSurface and use cairo APIs to put UI to the NvBufSurface. You can convert the surface to RGBA through nvvidconv plugin, and implement the UI code in the plugin.
Source code of nvvidconv is in
Jetson Linux Release 36.5.2 | NVIDIA Developer
Driver Package (BSP) Sources
Sample of using cairo APIs:
Tx2-4g r32.3.1 nvivafilter performance - #16 by DaneLLL
Cairo utilizes CPU to draw the UI right?
Is there some hardware accelerator options for rendering the UI?
Further, I could not find any proper documentation for Cairo APIs
FYI: I am using Jetson Orin Nano with Jetpack 6.2.1
For your questions,
And I implemented a sample patch for your scenario based on our existing pipeline.
You could refer to the attached Cairo overlay sample. We tested it on an AGX Orin Developer Kit running Jetson Linux r39.2.1.
cario_sample_patch.tar.xz (2.8 KB)
