Ultralytics install
ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: ‘/home/nano/.local/lib/python3.9/site-packages/pytz’
Check the permissions.
How to edit permissions? i cant even find the file or folder where the file is. I was installing ultralytics using the pip3 install -r requirements.txt
thanks for answering
Could you try to run it with sudo or add the --user to the command?
i tried doing both, but still the same output
Could you share the complete commands and output log with us?
nano@nano-desktop:~/yolov5$ pip3 install -r requirements.txt
Defaulting to user installation because normal site-packages is not writeable
Collecting gitpython>=3.1.30 (from -r requirements.txt (line 5))
Downloading GitPython-3.1.40-py3-none-any.whl.metadata (12 kB)
Collecting matplotlib>=3.3 (from -r requirements.txt (line 6))
Downloading matplotlib-3.8.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (5.8 kB)
Requirement already satisfied: numpy>=1.22.2 in /usr/local/lib/python3.9/site-packages (from -r requirements.txt (line 7)) (1.26.2)
Requirement already satisfied: Pillow>=10.0.1 in /usr/local/lib/python3.9/site-packages (from -r requirements.txt (line 9)) (10.1.0)
Requirement already satisfied: psutil in /usr/local/lib/python3.9/site-packages (from -r requirements.txt (line 10)) (5.9.6)
Requirement already satisfied: PyYAML>=5.3.1 in /usr/local/lib/python3.9/site-packages (from -r requirements.txt (line 11)) (6.0.1)
Requirement already satisfied: requests>=2.23.0 in /usr/local/lib/python3.9/site-packages (from -r requirements.txt (line 12)) (2.31.0)
Collecting scipy>=1.4.1 (from -r requirements.txt (line 13))
Downloading scipy-1.11.4-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (60 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 60.4/60.4 kB 2.2 MB/s eta 0:00:00
Collecting thop>=0.1.1 (from -r requirements.txt (line 14))
Downloading thop-0.1.1.post2209072238-py3-none-any.whl (15 kB)
Collecting tqdm>=4.64.0 (from -r requirements.txt (line 17))
Downloading tqdm-4.66.1-py3-none-any.whl.metadata (57 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 57.6/57.6 kB 2.1 MB/s eta 0:00:00
Collecting ultralytics>=8.0.147 (from -r requirements.txt (line 18))
Downloading ultralytics-8.0.212-py3-none-any.whl.metadata (31 kB)
Collecting pandas>=1.1.4 (from -r requirements.txt (line 27))
Downloading pandas-2.1.3-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (18 kB)
Collecting seaborn>=0.11.0 (from -r requirements.txt (line 28))
Downloading seaborn-0.13.0-py3-none-any.whl.metadata (5.3 kB)
Collecting setuptools>=65.5.1 (from -r requirements.txt (line 42))
Downloading setuptools-68.2.2-py3-none-any.whl.metadata (6.3 kB)
Collecting gitdb<5,>=4.0.1 (from gitpython>=3.1.30->-r requirements.txt (line 5))
Downloading gitdb-4.0.11-py3-none-any.whl.metadata (1.2 kB)
Collecting contourpy>=1.0.1 (from matplotlib>=3.3->-r requirements.txt (line 6))
Downloading contourpy-1.2.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (5.8 kB)
Collecting cycler>=0.10 (from matplotlib>=3.3->-r requirements.txt (line 6))
Downloading cycler-0.12.1-py3-none-any.whl.metadata (3.8 kB)
Collecting fonttools>=4.22.0 (from matplotlib>=3.3->-r requirements.txt (line 6))
Downloading fonttools-4.44.3-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (154 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 154.6/154.6 kB 5.0 MB/s eta 0:00:00
Collecting kiwisolver>=1.3.1 (from matplotlib>=3.3->-r requirements.txt (line 6))
Downloading kiwisolver-1.4.5-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (6.4 kB)
Requirement already satisfied: packaging>=20.0 in /usr/local/lib/python3.9/site-packages (from matplotlib>=3.3->-r requirements.txt (line 6)) (23.2)
Collecting pyparsing>=2.3.1 (from matplotlib>=3.3->-r requirements.txt (line 6))
Downloading pyparsing-3.1.1-py3-none-any.whl.metadata (5.1 kB)
Collecting python-dateutil>=2.7 (from matplotlib>=3.3->-r requirements.txt (line 6))
Downloading python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 247.7/247.7 kB 822.3 kB/s eta 0:00:00
Collecting importlib-resources>=3.2.0 (from matplotlib>=3.3->-r requirements.txt (line 6))
Downloading importlib_resources-6.1.1-py3-none-any.whl.metadata (4.1 kB)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/site-packages (from requests>=2.23.0->-r requirements.txt (line 12)) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/site-packages (from requests>=2.23.0->-r requirements.txt (line 12)) (3.4)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/site-packages (from requests>=2.23.0->-r requirements.txt (line 12)) (2.1.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/site-packages (from requests>=2.23.0->-r requirements.txt (line 12)) (2023.7.22)
Requirement already satisfied: torch in /usr/local/lib/python3.9/site-packages (from thop>=0.1.1->-r requirements.txt (line 14)) (1.10.0a0+git36449ea)
Collecting opencv-python>=4.6.0 (from ultralytics>=8.0.147->-r requirements.txt (line 18))
Downloading opencv_python-4.8.1.78-cp37-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (19 kB)
Requirement already satisfied: torchvision>=0.9.0 in /usr/local/lib/python3.9/site-packages (from ultralytics>=8.0.147->-r requirements.txt (line 18)) (0.10.0a0+05eae32)
Collecting py-cpuinfo (from ultralytics>=8.0.147->-r requirements.txt (line 18))
Downloading py_cpuinfo-9.0.0-py3-none-any.whl (22 kB)
Collecting pytz>=2020.1 (from pandas>=1.1.4->-r requirements.txt (line 27))
Downloading pytz-2023.3.post1-py2.py3-none-any.whl.metadata (22 kB)
Collecting tzdata>=2022.1 (from pandas>=1.1.4->-r requirements.txt (line 27))
Downloading tzdata-2023.3-py2.py3-none-any.whl (341 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 341.8/341.8 kB 5.4 MB/s eta 0:00:00
Collecting smmap<6,>=3.0.1 (from gitdb<5,>=4.0.1->gitpython>=3.1.30->-r requirements.txt (line 5))
Downloading smmap-5.0.1-py3-none-any.whl.metadata (4.3 kB)
Collecting zipp>=3.1.0 (from importlib-resources>=3.2.0->matplotlib>=3.3->-r requirements.txt (line 6))
Downloading zipp-3.17.0-py3-none-any.whl.metadata (3.7 kB)
Requirement already satisfied: six>=1.5 in /usr/local/lib/python3.9/site-packages (from python-dateutil>=2.7->matplotlib>=3.3->-r requirements.txt (line 6)) (1.16.0)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.9/site-packages (from torch->thop>=0.1.1->-r requirements.txt (line 14)) (4.8.0)
Downloading GitPython-3.1.40-py3-none-any.whl (190 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 190.6/190.6 kB 4.1 MB/s eta 0:00:00
Downloading matplotlib-3.8.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (11.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 11.4/11.4 MB 6.4 MB/s eta 0:00:00
Downloading scipy-1.11.4-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (33.0 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 33.0/33.0 MB 3.4 MB/s eta 0:00:00
Downloading tqdm-4.66.1-py3-none-any.whl (78 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 78.3/78.3 kB 2.8 MB/s eta 0:00:00
Downloading ultralytics-8.0.212-py3-none-any.whl (645 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 645.2/645.2 kB 7.5 MB/s eta 0:00:00
Downloading pandas-2.1.3-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (14.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 14.9/14.9 MB 2.1 MB/s eta 0:00:00
Downloading seaborn-0.13.0-py3-none-any.whl (294 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 294.6/294.6 kB 6.6 MB/s eta 0:00:00
Downloading setuptools-68.2.2-py3-none-any.whl (807 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 807.9/807.9 kB 7.7 MB/s eta 0:00:00
Downloading contourpy-1.2.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (292 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 292.6/292.6 kB 6.1 MB/s eta 0:00:00
Downloading cycler-0.12.1-py3-none-any.whl (8.3 kB)
Downloading fonttools-4.44.3-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (4.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.5/4.5 MB 8.4 MB/s eta 0:00:00
Downloading gitdb-4.0.11-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.7/62.7 kB 1.8 MB/s eta 0:00:00
Downloading importlib_resources-6.1.1-py3-none-any.whl (33 kB)
Downloading kiwisolver-1.4.5-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.4/1.4 MB 7.8 MB/s eta 0:00:00
Downloading opencv_python-4.8.1.78-cp37-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (41.0 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 41.0/41.0 MB 4.2 MB/s eta 0:00:00
Downloading pyparsing-3.1.1-py3-none-any.whl (103 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 103.1/103.1 kB 3.7 MB/s eta 0:00:00
Downloading pytz-2023.3.post1-py2.py3-none-any.whl (502 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 502.5/502.5 kB 8.4 MB/s eta 0:00:00
Downloading smmap-5.0.1-py3-none-any.whl (24 kB)
Downloading zipp-3.17.0-py3-none-any.whl (7.4 kB)
Installing collected packages: pytz, py-cpuinfo, zipp, tzdata, tqdm, smmap, setuptools, scipy, python-dateutil, pyparsing, opencv-python, kiwisolver, fonttools, cycler, contourpy, thop, pandas, importlib-resources, gitdb, matplotlib, gitpython, seaborn, ultralytics
context: I have installed python3.9 to ensure i can successfully install ultralytics since it needs python 3.7 and above and jetson nano only has 3.6.9. I have also installed opencv with cuda, torch and torchvision. The guide i used was the qengineering one. and the steps for the ultralytics install are on this document: NVIDIA Jetson Nano Deployment - Ultralytics YOLOv8 Docs
