@ubuntu:~$ python3 -m pip install --upgrade pip; python3 -m pip install aiohttp numpy=='1.19.4' scipy=='1.5.3' export "LD_LIBRARY_PATH=/usr/lib/llvm-8/lib:$LD_LIBRARY_PATH"; python3 -m pip install --upgrade protobuf; python3 -m pip install --no-cache $TORCH_INSTALL
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: pip in ./.local/lib/python3.8/site-packages (22.3.1)
ERROR: Invalid requirement: 'LD_LIBRARY_PATH=/usr/lib/llvm-8/lib:/usr/local/cuda-11.4/lib64:'
Hint: It looks like a path. File 'LD_LIBRARY_PATH=/usr/lib/llvm-8/lib:/usr/local/cuda-11.4/lib64:' does not exist.
Requirement already satisfied: protobuf in ./.local/lib/python3.8/site-packages (4.21.10)
Collecting https://developer.download.nvidia.cn/compute/redist/jp/v502/pytorch/1.13.0a0+936e930.nv22.11
ERROR: HTTP error 404 while getting https://developer.download.nvidia.cn/compute/redist/jp/v502/pytorch/1.13.0a0+936e930.nv22.11
ERROR: Could not install requirement https://developer.download.nvidia.cn/compute/redist/jp/v502/pytorch/1.13.0a0+936e930.nv22.11 because of HTTP error 404 Client Error: Not Found for url: https://developer.download.nvidia.cn/compute/redist/jp/v502/pytorch/1.13.0a0+936e930.nv22.11 for URL https://developer.download.nvidia.cn/compute/redist/jp/v502/pytorch/1.13.0a0+936e930.nv22.11
Iβm getting ERROR: torch-1.11.0a0+17540c5+nv22.01-cp36-cp36m-linux_aarch64.whl is not a supported wheel on this platform.; where can I find the correct torch version for my board?
It installed but Iβm seeing some errors/warnings, are these OK?
Collecting torch==1.13.0a0+936e9305.nv22.11
Downloading https://developer.download.nvidia.com/compute/redist/jp/v502/pytorch/torch-1.13.0a0+936e9305.nv22.11-cp38-cp38-linux_aarch64.whl (573.8 MB)
βββββββββββββββββββββββββββββββββββββββ 573.8/573.8 MB 3.5 MB/s eta 0:00:00
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.8/dist-packages (from torch==1.13.0a0+936e9305.nv22.11) (4.4.0)
Installing collected packages: torch
WARNING: The scripts convert-caffe2-to-onnx, convert-onnx-to-caffe2 and torchrun are installed in '/home/prakashlab/.local/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
Successfully installed torch-1.13.0a0+936e9305.nv22.11
It does look like it is functioning properly:
@ubuntu:~$ python3
Python 3.8.10 (default, Jun 22 2022, 20:18:18)
[GCC 9.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> torch.cuda.is_available()
True
