"unable to allocate CUDA0 buffer" after Updating Ubuntu Packages
Yes, there will be a public release for r35 as well.
Just wanted to say thank you. This got me working again and thanks to Ashwin for the original work, you guys are amazing
ggilman, the script worked flawlessly for me as well and resolved the CUDA allocation error/memory fragmentation issues. Thank you for sharing it.
Is there still no official guidance? I’m uncomfortable running community scripts that have such a deep effect.
They released 36.5.. supposed to be fixing this.. I am still trying it now but thought I update this thread
Update: it worked!
Thanks for the info. I follow the instructions. Looks like I can run the bigger models again, yay! By bigger models I mean up to 8.0B.
BTW I followed the instruction on the update link, but could not run: sudo apt install --fix-broken -o Dpkg: :=“–force-overwrite”
Received the following error: E: Option Dpkg:: Configuration item specification must have an =.
I’m not sure it matters cause everything seems to running ok, will monitor and report back with any issues.
try this:
sudo apt install --fix-broken -o Dpkg::Options::=“–force-overwrite”
