Hello All,
I have problems setting memory clock.
When i try to change MEM Clock to 810 Mhz and SM Clock to 506, SM clock settting succesfull, but nothing changes on Memory Clock.
nvidia-smi -pm 1
nvidia-smi -ac 810,506 -i 0
nvidia-smi -q -d CLOCK
==============NVSMI LOG==============
Timestamp : Thu Dec 13 06:13:05 2018
Driver Version : 410.72
CUDA Version : 10.0
Attached GPUs : 1
GPU 00000000:83:00.0
Clocks
Graphics : 506 MHz
SM : 506 MHz
Memory : 3499 MHz
Video : 658 MHz
Applications Clocks
Graphics : 506 MHz
Memory : 810 MHz
Default Applications Clocks
Graphics : 1075 MHz
Memory : 3504 MHz
Max Clocks
Graphics : 1721 MHz
SM : 1721 MHz
Memory : 3504 MHz
Video : 1556 MHz
Max Customer Boost Clocks
Graphics : 1721 MHz
SM Clock Samples
Duration : 52136.54 sec
Number of Samples : 76
Max : 1721 MHz
Min : 139 MHz
Avg : 1075 MHz
Memory Clock Samples
Duration : 52133.32 sec
Max : 3504 MHz
Min : 405 MHz
Avg : 408 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
As you see below mclk is still 3499 but i set it to 810.
# gpu pwr gtemp mtemp sm mem enc dec mclk pclk
# Idx W C C % % % % MHz MHz
0 17 44 - 0 0 0 0 3499 506
0 21 44 - 36 6 50 28 3499 506
0 22 44 - 98 14 100 48 3499 506
When i check GPUPerfModes, it says “editable=0”
DISPLAY=:0 XAUTHORITY=/var/run/lightdm/root/:0 nvidia-settings -q '[gpu:0]/GPUPerfModes'
Attribute 'GPUPerfModes' (ffmpeg-4:0[gpu:0]):
perf=0, nvclock=139, nvclockmin=139, nvclockmax=607, nvclockeditable=0, memclock=405, memclockmin=405, memclockmax=405,
memclockeditable=0, memTransferRate=810, memTransferRatemin=810, memTransferRatemax=810, memTransferRateeditable=0 ;
perf=1, nvclock=139, nvclockmin=139, nvclockmax=1721,
nvclockeditable=0, memclock=810, memclockmin=810, memclockmax=810, memclockeditable=0, memTransferRate=1620, memTransferRatemin=1620, memTransferRatemax=1620,
perf=2, nvclock=139, nvclockmin=139, nvclockmax=1721, nvclockeditable=0, memclock=3504, memclockmin=3504, memclockmax=3504, memclockeditable=0,
memTransferRate=7008, memTransferRatemin=7008, memTransferRatemax=7008, memTransferRateeditable=0
I tried to set rateofset, it returns “it is a read-only attribute”.
DISPLAY=:0 XAUTHORITY=/var/run/lightdm/root/:0 nvidia-settings -a '[gpu:0]/GPUMemoryTransferRateOffset[0]=1000'
ERROR: The attribute 'GPUMemoryTransferRateOffset' specified in assignment '[gpu:0]/GPUMemoryTransferRateOffset[0]=1000' cannot be assigned (it is a read-only attribute).
Also locked gpu clocks is not supported.
nvidia-smi -lgc 810,506
Setting locked Gpu clocks is not supported for GPU 00000000:83:00.0.
Treating as warning and moving on.
Is there any other way to change memory clock permanently?
nvidia-bug-report.log.gz (836 KB)
