Unable to control second graphics card through nvidia-settings
I have a headless rig with nine nvidia cards based on the P106-100 chipset running Ubuntu 16.04/x86_64. All cards are accessed through nvidia driver version 396.26 and are known to be operational, i.e. software runs on them. After setting Coolbits in xorg.conf for all cards (and making sure the xorg.conf is not reset by the system afterwards), I have tried to change the card’s clock speeds with the following commands from the command line:
nvidia-smi -pm 1
nvidia-settings -a [gpu:0]/GPUGraphicsClockOffset[2]=100
nvidia-settings -a [gpu:1]/GPUGraphicsClockOffset[2]=100
nvidia-settings -a [gpu:2]/GPUGraphicsClockOffset[2]=100
The second command indeed raises clock speed and power consumption of card 0, and it also prints a reply that indicates success:
Attribute 'GPUGraphicsClockOffset' (HPO-02-40:0[gpu:0]) assigned value 100.
However, the following commands issued for the other GPUs print only an empty line, and what’s worse, they also do nothing (as indicated by nvidia-smi query).
I also get strange results when trying to set fan speeds:
$ nvidia-settings -a [fan:0]/GPUTargetFanSpeed=90
  Attribute 'GPUTargetFanSpeed' (HPO-02-40:0[fan:0]) assigned value 90.
$ nvidia-settings -a [fan:1]/GPUTargetFanSpeed=90
ERROR: Error assigning value 90 to attribute 'GPUTargetFanSpeed' (HPO-02-40:0[fan:1]) as specified in assignment '[fan:1]/GPUTargetFanSpeed=90' (Unknown Error).
For some reason I can only change behavior of fan:0 and not of any other GPU’s fan. Interestingly, I can use nvidia-settings command to set GPUPowerMizerMode for all graphic cards without problem. GPUFanControlState and GPUMemoryTransferRateOffset, on the other side, behave as GPUGraphicsClockOffset, i.e. I can only set them for the first card.
Any ideas what I did wrong?
Found something which might provide some insight:
$ nvidia-settings --verbose=all -a [gpu:4]/GPUGraphicsClockOffset[2]=250
WARNING: Attribute 'GPUGraphicsClockOffset' specified in assignment '[gpu:4]/GPUGraphicsClockOffset[2]=250' is not available on HPO-02-40:0[gpu:4].
Why would higher GPUs not support attribute ‘GPUGraphicsClockOffset’ ? These are all identical cards, and configured identically AFAIK including option Coolbits:
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
EndSection
Section "Device"
    Identifier "intel"
    Driver "modesetting"
    BusID "PCI:0@0:2:0"
    Option "AccelMethod" "None"
EndSection
Section "Screen"
    Identifier "intel"
    Device "intel"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:1@0:0:0"
    Option "ConstrainCursor" "off"
    Option "Coolbits" "31"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
    Option "AllowEmptyInitialConfiguration" "on"
    Option "IgnoreDisplayDevices" "CRT"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:2@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:3@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:5@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:8@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:9@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:10@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:11@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:12@0:0:0"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
EndSection
Here is the output from ‘nvidia-smi -q’ for reference:
[code]
Timestamp : Mon Jan 14 00:03:26 2019
Driver Version : 396.26
Attached GPUs : 9
GPU 00000000:01:00.0
Product Name : P106-100
Product Brand : GeForce
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Enabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-b257b192-fd38-c4f6-2d67-1bba6ffb1f6e
Minor Number : 0
VBIOS Version : 86.06.56.00.04
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x1C0710DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x1717998D
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 5000 KB/s
Rx Throughput : 20000 KB/s
Fan Speed : 90 %
Performance State : P0
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3039 MiB
Free : 3041 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 73 C
GPU Shutdown Temp : 102 C
GPU Slowdown Temp : 99 C
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 84.12 W
Power Limit : 140.00 W
Default Power Limit : 120.00 W
Enforced Power Limit : 140.00 W
Min Power Limit : 60.00 W
Max Power Limit : 140.00 W
Clocks
Graphics : 2088 MHz
SM : 2088 MHz
Memory : 4752 MHz
Video : 1873 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
Process ID : 922
Type : G
Used GPU Memory : 14 MiB
Process ID : 3456
Type : C
Used GPU Memory : 3015 MiB
GPU 00000000:02:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-176d04e7-2fe0-ce44-6c04-7d313b0ddc80
Minor Number : 1
MultiGPU Board : No
Board ID : 0x200
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x02
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:02:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Rx Throughput : 19000 KB/s
Fan Speed : 55 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : 60 C
Power Readings
Power Draw : 73.71 W
Clocks
Graphics : 1873 MHz
SM : 1873 MHz
Memory : 4006 MHz
Video : 1683 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
Process ID : 3456
Type : C
GPU 00000000:03:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-b81252f8-5488-4a94-d784-2dc327aa2df0
Minor Number : 2
MultiGPU Board : No
Board ID : 0x300
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x03
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:03:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 51 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : 53 C
Power Readings
Power Draw : 72.37 W
Clocks
Graphics : 1860 MHz
SM : 1860 MHz
Memory : 4006 MHz
Video : 1670 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
Type : C
GPU 00000000:05:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-e6ace219-f729-9992-9415-e8bf0f0b22df
Minor Number : 3
MultiGPU Board : No
Board ID : 0x500
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x05
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:05:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 53 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : 57 C
Power Readings
Power Draw : 70.36 W
Clocks
Graphics : 1885 MHz
SM : 1885 MHz
Memory : 4006 MHz
Video : 1695 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
Process ID : 3456
Type : C
GPU 00000000:08:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-0f618530-4130-2e63-4ecb-1a0bb0688dc0
Minor Number : 4
MultiGPU Board : No
Board ID : 0x800
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x08
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:08:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Tx Throughput : 4000 KB/s
Rx Throughput : 16000 KB/s
Fan Speed : 54 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
Power Readings
Power Draw : 68.57 W
Clocks
Graphics : 1860 MHz
SM : 1860 MHz
Memory : 4006 MHz
Video : 1670 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
Process ID : 3456
Type : C
GPU 00000000:09:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-b13e8fa9-9527-b108-6db4-c710f2d4fd51
Minor Number : 5
MultiGPU Board : No
Board ID : 0x900
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x09
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:09:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 54 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
Power Readings
Power Draw : 73.43 W
Clocks
Graphics : 1885 MHz
SM : 1885 MHz
Memory : 4006 MHz
Video : 1695 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
Process ID : 3456
Type : C
GPU 00000000:0A:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-1082b770-fc38-80c1-f8c9-e1e11915882e
Minor Number : 6
MultiGPU Board : No
Board ID : 0xa00
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x0A
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:0A:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 56 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : 62 C
Power Readings
Power Draw : 72.24 W
Clocks
Graphics : 1873 MHz
SM : 1873 MHz
Memory : 4006 MHz
Video : 1683 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
Process ID : 3456
Type : C
GPU 00000000:0B:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-a3f6d253-1c6e-d249-1497-eb76fd07e76d
Minor Number : 7
MultiGPU Board : No
Board ID : 0xb00
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x0B
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:0B:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 54 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : 58 C
Power Readings
Power Draw : 71.32 W
Clocks
Graphics : 1873 MHz
SM : 1873 MHz
Memory : 4006 MHz
Video : 1683 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
Process ID : 3456
Type : C
GPU 00000000:0C:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-0ee1545f-872e-ee9c-3066-c8c7187a7b5b
Minor Number : 8
MultiGPU Board : No
Board ID : 0xc00
Inforom Version
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x0C
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:0C:00.0
GPU Link Info
PCIe Generation
Max : 1
Current : 1
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 55 %
Idle : Not Active
FB Memory Usage
Total : 6080 MiB
Used : 3025 MiB
Free : 3055 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Utilization
Gpu : 100 %
Memory : 100 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : 61 C
Power Readings
Power Draw : 71.38 W
Clocks
Graphics : 1873 MHz
SM : 1873 MHz
Memory : 4006 MHz
Video : 1683 MHz
Applications Clocks
Graphic
At long last I found a solution here.
