Nvidia-smi show H100 run at full load but power consumption only ~110w
nvidia-smi show H100 run at full load (100% GPU util), power consumption only ~110w, but max capacity is 700w, is this normal?
some more details:
nvidia-smi -q
root@node13:~# nvidia-smi -q
==============NVSMI LOG==============
Timestamp                                 : Tue Jul 16 11:05:16 2024
Driver Version                            : 535.154.05
CUDA Version                              : 12.2
Attached GPUs                             : 8
GPU 00000000:18:00.0
    Product Name                          : NVIDIA H100 80GB HBM3
    Product Brand                         : NVIDIA
    Product Architecture                  : Hopper
    Display Mode                          : Enabled
    Display Active                        : Disabled
    Persistence Mode                      : Enabled
    Addressing Mode                       : None
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : ******
    GPU UUID                              : ******
    Minor Number                          : 0
    VBIOS Version                         : 96.00.89.00.01
    MultiGPU Board                        : No
    Board ID                              : ******
    Board Part Number                     : ******
    GPU Part Number                       : ******
    FRU Part Number                       : N/A
    Module ID                             : 2
    Inforom Version
        Image Version                     : G520.0200.00.05
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : 2024/07/14 16:14:10.701
        Latest Duration                   : 92485 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GSP Firmware Version                  : 535.154.05
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
    GPU Reset Status
        Reset Required                    : No
        Drain and Reset Recommended       : No
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x18
        Device                            : 0x00
        Domain                            : 0x0000
        Device Id                         : 0x233010DE
        Bus Id                            : 00000000:18:00.0
        Sub System Id                     : 0x16C110DE
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 235292 KB/s
        Rx Throughput                     : 1554507 KB/s
        Atomic Caps Inbound               : N/A
        Atomic Caps Outbound              : N/A
    Fan Speed                             : N/A
    Performance State                     : P0
    Clocks Event Reasons
        Idle                              : Not Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 66839 MiB
        Free                              : 14168 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 5 MiB
        Free                              : 131067 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
            SRAM Correctable              : 0
            SRAM Uncorrectable            : 0
            DRAM Correctable              : 0
            DRAM Uncorrectable            : 0
        Aggregate
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows
        Correctable Error                 : 0
        Uncorrectable Error               : 0
        Pending                           : No
        Remapping Failure Occurred        : No
        Bank Remap Availability Histogram
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 28 C
        GPU T.Limit Temp                  : 58 C
        GPU Shutdown T.Limit Temp         : -8 C
        GPU Slowdown T.Limit Temp         : -2 C
        GPU Max Operating T.Limit Temp    : 0 C
        GPU Target Temperature            : N/A
        Memory Current Temp               : 37 C
        Memory Max Operating T.Limit Temp : 0 C
    GPU Power Readings
        Power Draw                        : 110.69 W
        Current Power Limit               : 700.00 W
        Requested Power Limit             : 700.00 W
        Default Power Limit               : 700.00 W
        Min Power Limit                   : 200.00 W
        Max Power Limit                   : 700.00 W
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Default Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Max Customer Boost Clocks
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : 925.000 mV
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 8464
            Type                          : C
            Used GPU Memory               : 66830 MiB
GPU 00000000:2A:00.0
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    GPU UUID                              : ******
    Minor Number                          : 1
    MultiGPU Board                        : No
    Board ID                              : ******
    Module ID                             : 4
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Latest Timestamp                  : 2024/07/14 16:14:10.586
        Latest Duration                   : 94166 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x2A
        Device                            : 0x00
        Domain                            : 0x0000
        Bus Id                            : 00000000:2A:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 4
        Tx Throughput                     : 1160101 KB/s
        Rx Throughput                     : 11340863 KB/s
    Fan Speed                             : N/A
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 71401 MiB
        Free                              : 9606 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 1877 MiB
        Free                              : 129195 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 31 C
        GPU T.Limit Temp                  : 55 C
        Memory Current Temp               : 36 C
    GPU Power Readings
        Power Draw                        : 119.92 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
        Graphics                          : 935.000 mV
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        Process ID                        : 8465
            Type                          : C
            Used GPU Memory               : 71392 MiB
GPU 00000000:3A:00.0
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    GPU UUID                              : ******
    Minor Number                          : 2
    MultiGPU Board                        : No
    Board ID                              : ******
    Module ID                             : 1
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Latest Timestamp                  : 2024/07/14 16:14:10.023
        Latest Duration                   : 91434 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x3A
        Device                            : 0x00
        Domain                            : 0x0000
        Bus Id                            : 00000000:3A:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 1
        Tx Throughput                     : 208089 KB/s
        Rx Throughput                     : 1505625 KB/s
    Fan Speed                             : N/A
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 70917 MiB
        Free                              : 10090 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 5 MiB
        Free                              : 131067 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 32 C
        Memory Current Temp               : 40 C
    GPU Power Readings
        Power Draw                        : 112.36 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        Process ID                        : 8466
            Type                          : C
            Used GPU Memory               : 70908 MiB
GPU 00000000:5D:00.0
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    GPU UUID                              : ******
    Minor Number                          : 3
    MultiGPU Board                        : No
    Board ID                              : ******
    Module ID                             : 3
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Latest Timestamp                  : 2024/07/14 16:14:16.050
        Latest Duration                   : 128204 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x5D
        Device                            : 0x00
        Domain                            : 0x0000
        Bus Id                            : 00000000:5D:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Tx Throughput                     : 317777 KB/s
        Rx Throughput                     : 1984734 KB/s
    Fan Speed                             : N/A
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 77299 MiB
        Free                              : 3708 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 2085 MiB
        Free                              : 128987 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU T.Limit Temp                  : 59 C
    GPU Power Readings
        Power Draw                        : 113.84 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        Process ID                        : 8467
            Type                          : C
            Used GPU Memory               : 77290 MiB
GPU 00000000:9A:00.0
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    GPU UUID                              : ******
    Minor Number                          : 4
    MultiGPU Board                        : No
    Board ID                              : ******
    Module ID                             : 6
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Latest Timestamp                  : 2024/07/14 16:14:10.688
        Latest Duration                   : 92496 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x9A
        Device                            : 0x00
        Domain                            : 0x0000
        Bus Id                            : 00000000:9A:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 6
        Tx Throughput                     : 1387984 KB/s
        Rx Throughput                     : 13858941 KB/s
    Fan Speed                             : N/A
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 80645 MiB
        Free                              : 362 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 5 MiB
        Free                              : 131067 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 27 C
    GPU Power Readings
        Power Draw                        : 109.72 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        Process ID                        : 8469
            Type                          : C
            Used GPU Memory               : 80636 MiB
GPU 00000000:AB:00.0
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    GPU UUID                              : ******
    Minor Number                          : 5
    MultiGPU Board                        : No
    Board ID                              : ******
    Module ID                             : 8
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Latest Timestamp                  : 2024/07/14 16:14:19.040
        Latest Duration                   : 89437 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0xAB
        Device                            : 0x00
        Domain                            : 0x0000
        Bus Id                            : 00000000:AB:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 5
        Tx Throughput                     : 1169238 KB/s
        Rx Throughput                     : 11799937 KB/s
    Fan Speed                             : N/A
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 54637 MiB
        Free                              : 26370 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 1877 MiB
        Free                              : 129195 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU T.Limit Temp                  : 56 C
    GPU Power Readings
        Power Draw                        : 112.70 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        Process ID                        : 8470
            Type                          : C
            Used GPU Memory               : 54628 MiB
GPU 00000000:BA:00.0
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    GPU UUID                              : ******
    Minor Number                          : 6
    MultiGPU Board                        : No
    Board ID                              : ******
    Module ID                             : 5
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Latest Timestamp                  : 2024/07/14 16:14:11.744
        Latest Duration                   : 125255 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0xBA
        Device                            : 0x00
        Domain                            : 0x0000
        Bus Id                            : 00000000:BA:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Tx Throughput                     : 263601 KB/s
        Rx Throughput                     : 1608136 KB/s
    Fan Speed                             : N/A
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 75633 MiB
        Free                              : 5374 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 5 MiB
        Free                              : 131067 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
    GPU Power Readings
        Power Draw                        : 115.33 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        Process ID                        : 8471
            Type                          : C
            Used GPU Memory               : 75624 MiB
GPU 00000000:DB:00.0
    MIG Mode
        Current                           : Disabled
        Pending                           : Disabled
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    GPU UUID                              : ******
    Minor Number                          : 7
    MultiGPU Board                        : No
    Board ID                              : ******
    Module ID                             : 7
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 7.16
        Latest Timestamp                  : 2024/07/14 16:14:10.912
        Latest Duration                   : 126188 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0xDB
        Device                            : 0x00
        Domain                            : 0x0000
        Bus Id                            : 00000000:DB:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 5
                Current                   : 5
                Device Current            : 5
                Device Max                : 5
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 11
        Tx Throughput                     : 1812390 KB/s
        Rx Throughput                     : 1477725 KB/s
    Fan Speed                             : N/A
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 81559 MiB
        Reserved                          : 551 MiB
        Used                              : 73259 MiB
        Free                              : 7748 MiB
    BAR1 Memory Usage
        Total                             : 131072 MiB
        Used                              : 2085 MiB
        Free                              : 128987 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 100 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 2560 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 29 C
        Memory Current Temp               : 35 C
    GPU Power Readings
        Power Draw                        : 113.51 W
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
    Applications Clocks
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
        Graphics                          : 1980 MHz
        Memory                            : 2619 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1980 MHz
        SM                                : 1980 MHz
        Memory                            : 2619 MHz
        Video                             : 1545 MHz
        Graphics                          : 1980 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : Completed
        Status                            : Success
    Processes
        Process ID                        : 8472
            Type                          : C
            Used GPU Memory               : 73250 MiB
Util here just means it’s doing something rather than sitting there idling, but it doesn’t mean it’s doing heavy lifting.
Low energy consumption at high util is an indicator that your application isn’t running efficiently.
