Unable to find generated .tfrecord file
• Hardware (T4/V100/Xavier/Nano/etc) : ** x86_64 GPU machine**
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) : ** detectnet_v2
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) : i can able to run container
• Training spec file(If have, please share here): attached log
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I’m trying to do dataset conversion in tao toolkit. log shows tfrecord generation was successful. But i couldn’t see generated tfrecord files in given result path.
dataset used: PASCAL VOC 2012 dataset → converted to KITTI format → dataset_convert_config file
data_convert_config_spec.txt (409 Bytes)
command: tao detectnet_v2 dataset_convert -v -d /home/soundarrajan/detectnet_v2/config/data_convert_config_spec.txt -o /home/soundarrajan/detectnet_v2/result --log_file /home/soundarrajan/detectnet_v2/result/dataset_convert_log.txt
Output:
dataset_convert_log.txt (4.3 KB)
.tao_mount.json file used:
.tao_mounts.json (491 Bytes)
Actually the command was executed successfully as you can see the attached logs. But i couldn’t able to find the converted .tfrecord file in given output folder -o home/soundarrajan/detectnet_v2/result
In which path the converted .tfrecord will be saved to?
Kindly refer the config file and .tao_mounts.json file i attached, is anything missing in config and help to fix it.
Fix this issue in Tao toolkit container not installing - #25 by Morganh
