I am unable to flash the NVME on a Jetson Orin Nano Dev Kit. I am using r36.2 (Jetpack 6.0DP) which is a requirement as we needed the exact Linux kernel on this release. I am using the instructions here Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation on an Ubuntu 20.04 computer.
These are the files used (from Jetson Linux 36.2 | NVIDIA Developer):
- Jetson_Linux_R36.2.0_aarch64.tbz2
- Tegra_Linux_Sample-Root-Filesystem_R36.2.0_aarch64.tbz2
I am specifically using the command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-orin-nano-devkit internal
Running this command, it always times out and i kept on getting the message:
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Cleaning up...
Attached is the log from the serial of Jetson Nano
putty.log (78.0 KB)
Also, i tried the following:
- Flashing the internal emmc works using
sudo ./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internalI was able to boot-up the Jetson Nano without the NVME nor SD card. - Using SDK Manager 2.2.0, I was able to flash the NVME using Jetpack 6.0 Rev 2. Unfortunately, we need the Jetpack 6.0 DP.
- What could be the reason as to why the l4t_initrd_flash.sh command didn’t work?
- I prefer using the command from the quickstart but since the SDK Manager was able to flash the NVME, is there a way to be able to see Jetpack 6.0DP on the SDK Manager as we need the exact Linux kernel version on 6.0DP? Only 6.0 Rev 2 is accessible on the SDK manager.
thanks
