Jetpack 6.2 / L4T 36.4.3 - Orin Nano and NX won't boot after flashing NVME
We are having trouble flashing both the Nano and NX devkits with the latest Jetpack/L4T. Everything worked just fine on 36.4.0 and now the same commands result in errors during bootup after flashing the NVME. We get
mount /mnt: can't find PARTUUID=7231cb5e...
and then the device reboots.
Things we tried that did not work
  • Flash without ROOTFS_AB (the ‘default’ case in the instructions)
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit external
  • Flash with ROOTFS_AB enabled
# Generate images for QSPI
$ sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --no-flash --network usb0 jetson-orin-nano-devkit internal
# Generate images for external storage device
$ sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_ab.xml --external-only --append --network usb0 jetson-orin-nano-devkit external
# Flash images into the both storage devices
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
  • Swap the SSD
  • Try on an NX instead of a NANO
The flash log is here:
36.4.3-flash_5-2_0_20250219-132536.log (48.0 KB)
Please record the serial console log during the bootup.
To record the serial console log, please refer below link.
Thanks, I’m waiting for an FTDI to arrive. In the meantime I managed to flash the SDCard on a Nano Devkit and use it to try and see what’s wrong with booting from the NVMe.
I re-flashed both the NVMe and the SD Card with a minimal rootfs per Root File System — NVIDIA Jetson Linux Developer Guide 1 documentation
SD Card
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device mmcblk0p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
NVME
sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme_rootfs_ab.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
After running lsblk -o NAME,PARTUUID when booting from the SD Card I can see that all of the 16 required partitions (nvme0n1p1-16) are around and have the correct UUIDs - but booting from the NVME still fails to find and mount the existing partition.
Got it.
Please execute below commands and share result with us
 cat /boot/extlinux/extlinux.conf
Hey David,
I found the issue - it was related to the minimal flavor rootfs. It looks like there is a failure that bobbles up when running ./apply_binaries.shand later causes a broken boot. It invokes nv_tegra/nv-apply-debs.sh which fails because the following two debs are not around in the minimal flavor
  • nvidia-l4t-jetsonpower-gui-tools
  • nvidia-l4t-nvpmodel-gui-tools
Steps to reproduce are:
For us this reproducably caused a broken Orin. I had to patch nv_tegra/nv-apply-debs.sh to get it to work.
Thank you for your finding.
It seems like a bug.
We need to reproduce it to confirm and file the patch to fix in next release.
Could you provide the patch for us to try?
Sure, I inserted this bit at line 227 of nv_tegra/nv-apply-debs.sh:
deb_skiplist+=("nvidia-l4t-jetsonpower-gui-tools")
deb_skiplist+=("nvidia-l4t-nvpmodel-gui-tools")
Not sure if this would break the existing sample_fs build or if you’d need to add another flag.
