Unable to get interim transcripts for RIVA Unified Conformer ASR Japanese model
AWS EC2 g5.2xlarge instance.
Hardware - GPU (A10)
Hardware - CPU AMD EPYC 7R32
Operating System: Ubuntu 22.04 deep learning base img
Riva Version: 2.16.0.
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
  1. install riva quickstart, download all dependencies etc.
  2. in the config.sh script- set the following for the asr model-service_enabled_asr=true ,
    asr_language_code=(“ja-JP”)
    asr_acoustic_model=(“conformer”)
    asr_acoustic_model_variant=(“unified”) OR leave it “” empty
    use_asr_greedy_decoder=false
Run init and start scripts. In order to connect to the ASR service, use the sample app provided:
Ensure correct setup of env.txt file, correct server IP, language settings and interim_results set to true.
Issue:
The interim transcripts don’t appear in the server logs OR on the client side of the sample application. However, when I switch to the english language, I am able to see the interim results. Of course, I am able to see the final transcripts correctly in both cases (EN and JP)
Applicable models:
RIVA Conformer ASR Japanese
@anup2 Are you still experiencing this problem?
