I am having issues in installing skimage in a virtual environment.
I used the following :
python3 -m pip install -U scikit-image
pip3 install --upgrade scikit-image
python -m pip install scikit-image
pip install --upgrade --force-reinstall scikit-image
I also tried other similar issues raised in the forum and none of it works.
like :
Please help to resolve this issue.
Board details :
- NVIDIA Jetson Xavier NX (Developer Kit Version)
- Jetpack 4.5.1 [L4T 32.5.1]
Can you share a little bit more detail, like error messages you see during installation attempt?
@asgardian
you may try
sudo apt-get update
sudo apt-get install -y build-essential gfortran libatlas-base-dev
sudo pip3 install numpy cython sklearn
or
1. Dependencies
$ sudo apt-get install liblapack-dev gfortran
$ sudo apt-get install python3-pip
$ sudo pip3 install -U pip
$ sudo pip3 install Cython numpy
2. Scipy
$ wget https://github.com/scipy/scipy/releases/download/v1.3.3/scipy-1.3.3.tar.gz
$ tar -xzvf scipy-1.3.3.tar.gz scipy-1.3.3
$ cd scipy-1.3.3/
$ python3 setup.py install --user
3. Tiff
$ wget https://download.osgeo.org/libtiff/tiff-4.1.0.tar.gz
$ tar -xzvf tiff-4.1.0.tar.gz
$ cd tiff-4.1.0/
$ ./configure
$ make
$ sudo make install
4. Scikit-image
$ sudo apt-get install python3-sklearn
$ sudo apt-get install libaec-dev libblosc-dev libffi-dev libbrotli-dev libboost-all-dev libbz2-dev
$ sudo apt-get install libgif-dev libopenjp2-7-dev liblcms2-dev libjpeg-dev libjxr-dev liblz4-dev liblzma-dev libpng-dev libsnappy-dev libwebp-dev libzopfli-dev libzstd-dev
$ sudo pip3 install imagecodecs
$ sudo pip3 install scikit-image
source Install scikit-image - #12 by AastaLLL
Hi @Andrey1984 ,
I am getting the below error when I am executing “python3 setup.py install --user” command
Based on the screenshot you shared, it should be a warning rather than an error.
Does the building job terminate after the log?
Please noted that since building from the source, it may take some time to finish.
