There is also a unusual behaviour, when I try to log into developer.nvidia.com:
The direct login fails (same error message: incorrect email or password).
If I click on “CREATE AN ACCOUNT”, the next page let’s me choose an existing account and then - suddenly - I am logged into the developer space.
If the actual packages like Jetpack 4.2.1 could be downloaded separately, I could use the offline-mode of the sdkmanager. But I don’t find any download link.
NVIDIA SDK Manager was working fine on Friday 07/26, I was able to install it. But for the past couple of days, I am getting either “Incorrect email or password” or “Data received is invalid” error for "NVIDIA DEVELOPER - developer.nvidia.com’ login dialog. Because of repeated attempts, it even blocked login from my host machine, but received a email message, when I followed the link in email, I was able to unblock my IP address. Unblocking did not help, I saw the same error, so I decided to change the password. Changing the password did not help either. I tried the “sdkmanager --spectron --ignore-certificate-errors” command as well, it is still not working. I cannot login into developer.nvidia.com site using my email/password on my first attempt, but it gives me an option to login via the loginID button it shows.
I am still experiencing the issue being described by peter.muenstermann and sheetalg.
I can login to https://www.nvidia.com/en-us/account/ and view my account, but I cannot login properly to developer.nvidia.com. If I visit developer.nvidia.com I am given an option to select my username and I am then logged in, but logging in @ https://developer.nvidia.com with username and password fails. I am also unable to
login to the sdkmanager. In both cases, I receive the same error “Login failed: Incorrect email or password”
My credentials must be correct, that is how I am able to login to the forums. Something seems to be wrong with the login mechanism for these properties.
Hello! I seem to not be able to log in on SDK manager with my devloper.nvidia.com account. I keep getting a “Incorrect email or password”, despite having earlier reset my password.
Nvidia responded pretty quickly to this last time. As a work around I created a new account and logged in and that fixed it for me and I reverted to my original account a day later.
I’m having the same problem. I can access to my account on website but I get “Incorrect email or password” when I try login SDK Manager. I tried to change my password but the result is the same.
I have the same problem on the SDK manager. It looks like my IP was blocked and I did “unblock” the IP from the link provided in email. However after many hours, it looks like it still is giving me a response of Incorrect email or password.
