Unable to pull pretrained model from NGC
When I run this code
!ngc registry model download-version nvidia/tao/pretrained_object_detection:resnet18
–dest $LOCAL_EXPERIMENT_DIR/pretrained_resnet18
I get the following error:-
ngc: /tmp/_MEIjGHmAF/libstdc++.so.6: version CXXABI_1.3.8' not found (required by /usr/lib/x86_64-linux-gnu/libtcmalloc.so.4) ngc: /tmp/_MEIjGHmAF/libstdc++.so.6: version GLIBCXX_3.4.21’ not found (required by /usr/lib/x86_64-linux-gnu/libtcmalloc.so.4)
Please help
I have reinstalled libgcc but still face issue.
Also, is it possible to run TAO models without docker?
I am currently working on Google Colab.
Hi @ronakkhandelwal,
Welcome to the NVIDIA Developer forums. Your issue might be better served if posted in the TAO Toolkit category. I will move it over for you.
Best,
Tom K
How about
! ngc --help
I get the same error when I run !ngc --help
This is the code I am using to install ngc. Is it properly getting installed?
Installing NGC CLI on the local machine.
Download and install
%env CLI=ngccli_cat_linux.zip
!mkdir -p $LOCAL_PROJECT_DIR/ngccli
Remove any previously existing CLI installations
!rm -rf $LOCAL_PROJECT_DIR/ngccli/*
!wget “NVIDIA NGC” -P $LOCAL_PROJECT_DIR/ngccli
!unzip -u “$LOCAL_PROJECT_DIR/ngccli/$CLI” -d $LOCAL_PROJECT_DIR/ngccli/
!rm $LOCAL_PROJECT_DIR/ngccli/*.zip
os.environ[“PATH”]=“{}/ngccli:{}”.format(os.getenv(“LOCAL_PROJECT_DIR”, “”), os.getenv(“PATH”, “”))
Basically I am unable to run ngc. Please help!
Thanks and Regards,
Ronak Khandelwal
Since you are running in Google Colab, I can reproduce the same error in Colab while downloading NVIDIA NGC .
Not sure if the ngc is compatible with Google Colab.
For workaround, please use wget to download the model instead of ngc.
For example,
equals to
! wget https://api.ngc.nvidia.com/v2/models/nvidia/tao/pretrained_object_detection/versions/resnet18/files/resnet_18.hdf5
Refer to https://docs.nvidia.com/tao/tao-toolkit/text/open_images/open_images_pt_object_detection.htmlTAO Pretrained Object Detection | NVIDIA NGC
