hello,I have been using tao-toolkit yolov3 training for 1 month, it had no problem till today.
it doesn’t download pretrained model
“!ngc registry model download-version nvidia/tao/pretrained_object_detection:resnet18
–dest $LOCAL_EXPERIMENT_DIR/pretrained_resnet18”
After checking, I can download it successfully.
Please check if there is network issue on your side or something blocking issue. Thanks.
shi093
January 29, 2022, 2:26am
3
I had similar problem when I tried to download from NGC:
!ngc registry model download-version nvidia/tao/trafficcamnet:pruned_v1.0 --dest $NGC_DIR
[Transfer Error] Retrying in 10 seconds…
[Transfer Error] Retrying in 5 seconds…
[Transfer Error] Retrying in 33 seconds…
[Transfer Error] Retrying in 7 seconds…
[Transfer Error] Retrying in 61 seconds…
[Transfer Error] Retrying in 46 seconds…
[Transfer Error] Retrying in 65 seconds…
[Transfer Error] Retrying in 1 seconds…
[Transfer Error] Retrying in 29 seconds…
[Transfer Error] Retrying in 67 seconds…
[Transfer Error] Retrying in 59 seconds…
[Transfer Error] Retrying in 17 seconds…
[Transfer Error] Retrying in 57 seconds…
[Transfer Error] Retrying in 15 seconds…
Downloaded 0 B in 8m 30s, Download speed: 0 B/s
Maximum retry attempts reached (15). Unable to complete transfer.
Downloaded 0 B in 8m 31s, Download speed: 0 B/s
Transfer id: trafficcamnet_vpruned_v1.0 Download status: Failed.
Downloaded local path: /dli/task/ngc_assets/trafficcamnet_vpruned_v1.0
Total files downloaded: 0
Total downloaded size: 0 B
Started at: 2022-01-29 02:11:03.090326
Completed at: 2022-01-29 02:19:34.677244
Duration taken: 8m 31s
shi093
January 30, 2022, 7:57pm
6
Thanks for replying. But this does not solve my problem. I signed up a NVIDIA DLI online course, and I need to run this command inside that controlled environment of that course. The JupyterLab notebook is hosted on http://ec2-3-231-167-106.compute-1.amazonaws.com/lab/lab/tree/03_building_a_DeepStream_application.ipynb
I tried to email DLI about this issue, no luck so far.
hi, did you find any solution to this? I’m facing the same issue.
Me too , same issue with the command :
/ngccli/ngc registry model download-version nvidia/tao/pretrained_object_detection:resnet18 --dest .
solved by Morganh with wget
but it doesn’t work with CLI
Morganh
February 15, 2022, 3:27am
10
Could you retry CLI? Actually I cannot reproduce any error.
