Hello, I deleted the content in the config file before, so there is no property. Later, after I modified the config.txt, the following problems now appear:
I use SSH to connect to the server, I hope to save the results as a file, and then download to the local computer to display, how do I operate, thank you very much
these are for deepstream-app configuration, you should not put it under nvinfer configuration, please remove it. do not remove any property within configuration, you can add comment at the beginning of the line.
Sorry, I forgot to modify the path, but after the modification is completed, the problem is the same again.
The output is as follows:
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
Now playing: sample_720p.h264
pci id for fd 16: 1013:00b8, driver (null)
MESA-LOADER: failed to open cirrus (search paths /usr/lib/x86_64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
failed to load driver: cirrus
0:00:00.223402436 86270 0x5646cd1ac380 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
Warning, setting batch size to 1. Update the dimension after parsing due to using explicit batch size.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: TensorRT was linked against cuBLAS/cuBLAS LT 11.3.0 but loaded cuBLAS/cuBLAS LT 11.2.1
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:10.574137697 86270 0x5646cd1ac380 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine successfully
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:10.579825356 86270 0x5646cd1ac380 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running…
Please make sure you have display exported before you run. since test1 use nveglglessink which require display.
export DISPLAY=:0 or 1 //xrandr to check if display exported success or not.
You can use deepstream-app which have configuration about save to file.
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1 #encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000 #H264 Profile - 0=Baseline 2=Main 4=High #H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
hi,I am using deepstream-test1-app. Modifying the config does not work. I am now modifying the following code:
before fixing
sink = gst_element_factory_make (“fakesink”, “nvvideo-renderer”);
g_object_set (G_OBJECT(sink), “sync”, FALSE, NULL);
But when the execution reaches the 5th frame, the program stops:
Running…
Frame Number = 0 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 1 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 2 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 3 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Filesink is not one element, you can not directly use it. you can refer to sources/apps/apps-common/src/deepstream_sink_bin.c function create_encode_file_bin
