I try to compile my source file (file.cu) with nvcc on mac OSX.
I use instruction:
$ nvcc file.cu -o file
but I get the following output
Undefined symbols for architecture x86_64:
"std::istream::operator>>(double&)", referenced from:
_main in tmpxft_000002fa_00000000-16_prodotto.o
"std::istream::operator>>(int&)", referenced from:
"std::ostream::operator<<(std::ostream& (*)(std::ostream&))", referenced from:
"std::ostream::operator<<(double)", referenced from:
"std::ios_base::Init::Init()", referenced from:
___cxx_global_var_init in tmpxft_000002fa_00000000-16_prodotto.o
"std::ios_base::Init::~Init()", referenced from:
"std::cin", referenced from:
"std::cout", referenced from:
"std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)", referenced from:
"std::basic_ostream<char, std::char_traits<char> >& std::operator<<<std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)", referenced from:
"operator new[](unsigned long)", referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
What do I do?
