Understanding the balance between velocity, effort, and position
Continuing the discussion from Shadow Hand Joint State Control (Articulation controller not working):
Hi @dstokes181
Here is the documentation about articulation controller: ArticulationController API
You can use the API get_gains() to check what are the gains for the PD controller.
Here is the document about how to use python scripting with omni graph.
I hope this is helpful for your case.
