When writing data to ttyTHS1
, it will get data out of nowhere.
Python one-line reproducer for this:
sudo python -c 'from periphery import Serial; s = Serial("/dev/ttyTHS1", 115200); s.write(b"\xFF"); print(s.read(32, 0.1)); s.close()'
System information
AGX Orin devkit
nvidia@ubuntu:~$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.0, GCID: 37537400, BOARD: generic, EABI: aarch64, DATE: Fri Sep 13 04:36:44 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
Both UART1_TX
and UART1_RX
are connected to nothing.
Hi 5d867a92b9bdd01df324966db,
What do you mean about this?
Is there any error showing in dmesg at this moment?
How about you connect them together to perform loopback test?
Hi KevinFFF,
It means that RX is not connected but still receive data.
No.
It will work as expected. But is the behavior described above normal?
What data do you receive? \x00
It seems the issue relating to python script.
You can also get a scope to check if there’s any data from RX when you send 0xFF
from TX but TX/RX is disconnectd.
system
Closed
March 12, 2025, 12:56am
8
