UART7 RX can not work
UART7 Tx is can sen data out ,but RX can received data. Please help me find out the cause of the problem.
nvidia@nvidia-desktop:~$ dmesg | grep ‘tty’
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames= 0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069b000 lut_mem=0x2008 @0xa0695000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part _access=1 quiet
[ 0.001051] console [tty0] enabled
[ 2.188072] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 2.189717] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 2.191000] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 2.192573] c290000.serial: ttyTHS6 at MMIO 0xc290000 (irq = 53, base_baud = 0) is a TEGRA_UART
[ 2.194048] console [ttyTCU0] enabled
nvidia@nvidia-desktop:~$ sudo su
[sudo] password for nvidia:
root@nvidia-desktop:/home/nvidia# cat /sys/kernel/debug/tegra_pinctrl_reg
Bank: 1 Reg: 0x0c302000 Val: 0x00000400 → touch_clk_pcc4
Bank: 1 Reg: 0x0c302008 Val: 0x00000458 → uart3_rx_pcc6
Bank: 1 Reg: 0x0c302010 Val: 0x00000400 → uart3_tx_pcc5
Bank: 1 Reg: 0x0c302018 Val: 0x00000540 → gen8_i2c_sda_pdd2
Bank: 1 Reg: 0x0c302020 Val: 0x00000540 → gen8_i2c_scl_pdd1
Bank: 1 Reg: 0x0c302028 Val: 0x00000459 → spi2_mosi_pcc2
Bank: 1 Reg: 0x0c302030 Val: 0x00000440 → gen2_i2c_scl_pcc7
Bank: 1 Reg: 0x0c302038 Val: 0x00000401 → spi2_cs0_pcc3
Bank: 1 Reg: 0x0c302040 Val: 0x00000440 → gen2_i2c_sda_pdd0
Bank: 1 Reg: 0x0c302048 Val: 0x00000401 → spi2_sck_pcc0
Bank: 1 Reg: 0x0c302050 Val: 0x00000451 → spi2_miso_pcc1
hello gcs,
please also refer to this discussion thread, Topic 54572, for the steps to enable UART-7.
thanks
Hi JerryChang,
I’ve read the Topic 54572, and I changed the file ‘tegra194-a01-bpmp-p2888-a01.dtb’ as below:
    serial {
    /*      port = <0x3>;   */
            port = <0xf>;
            has_input;
            combined-uart {
                    enabled;
But, Rx still can not work(can not received data),
We found the cause of the problem,schematic design error.
