I am analyzing my vulkan graphic engine with a test case using Nsight Graphics GPU Trace (NSight Graphics 2025.5.0, Windows 11, RTX 4070-12G) , and I am seeing something that does not match my expectations of the GPU pipeline.
My scenario:
The entire scene is fully visible in the camera view.
All triangles are clearly inside the viewport after projection.
The geometry occupies only a region near the center of the screen.
No triangles appear to cross the viewport boundary.
However, Nsight reports VPC Discard Rate ≈ 80%.
This happens regardless of camera orientation:
Looking at the front of the object → ~80% VPC discard
Looking at the back of the object → still ~80% VPC discard
This suggests the discard rate is not simply caused by backface culling.
My questions:
1. Does the VPC stage include backface culling on NVIDIA hardware?
API-level documentation (DX/Vulkan/OpenGL) usually describes backface culling as part of the “rasterization stage”, but the NVIDIA technical blog says:
“VPC (Viewport Culling) does the viewport transform, frustum culling, and perspective correction of attributes.”
This implies VPC is the primitive‑level culling unit.
If so, does VPC also perform backface culling?
2. Even if backface culling is included, why is the discard rate as high as 80%?
Backface culling alone should account for roughly 50% of triangles in a closed mesh.
But I am consistently seeing ~80%, even when:
The camera is positioned so that almost all visible triangles are front‑facing
The scene is small and centered
No geometry appears clipped by the viewport
This suggests additional discard sources beyond backface culling.
3. Does VPC count “partial clipping” as a discard?
For example:
If a triangle has one vertex slightly outside NDC or guardband
The hardware clips the triangle and generates new primitives
Does Nsight count the original triangle as “discarded” in VPC statistics?
If yes, this could explain why VPC discard rate is much higher than expected, even when the final rasterized geometry is fully inside the viewport.
Summary of the issue:
Even in a very small scene where all triangles appear fully inside the viewport, Nsight reports ~80% VPC discard rate, which seems too high to be explained by backface culling alone.
I would like clarification on:
What operations are included in VPC discard statistics
Whether partial clipping counts as discard
Whether backface culling is performed in VPC
Why VPC discard can remain ~80% even when the camera orientation changes
Any official explanation of how VPC discard rate is computed on NVIDIA hardware would be greatly appreciated.
