I have an application that uses an NvBuffer and NvEglRenderer to display image data. Everything works as expected but at the end of my application it always prints the message: “NvEglHandle: Unfreed handle upon egl deinit: type=2 refcnt=2”.
Not sure if this means I have a memory leak or forgot to free something? I destroyed all NvBuffers used, so I’m not sure what could be causing this.
Please check if you call below APIs in pair for each NvBuffer:
* This method must be used for getting `EGLImage` from `dmabuf-fd`.
* @param[in] display `EGLDisplay` object used during the creation of `EGLImage`.
* @param[in] dmabuf_fd `DMABUF FD` of buffer from which `EGLImage` to be created.
* @returns `EGLImageKHR` for success, `NULL` for failure
EGLImageKHR NvEGLImageFromFd (EGLDisplay display, int dmabuf_fd);
* This method must be used for destroying `EGLImage` object.
* @param[in] display `EGLDisplay` object used for destroying `EGLImage`.
* @param[in] eglImage `EGLImageKHR` object to be destroyed.
* @returns 0 for success, -1 for failure
int NvDestroyEGLImage (EGLDisplay display, EGLImageKHR eglImage);
* This method must be used for getting mem mapped virtual Address of the plane.
* @param[in] dmabuf_fd DMABUF FD of buffer.
* @param[in] plane video frame plane.(Applicale for NvBufferPayload_SurfArray)
* @param[in] memflag NvBuffer memory flag.
* @param[in] pVirtAddr Virtual Addres pointer of the mem mapped plane.
* @returns 0 for success, -1 for failure.
int NvBufferMemMap (int dmabuf_fd, unsigned int plane, NvBufferMemFlags memflag, void **pVirtAddr);
* This method must be used to Unmap the mapped virtual Address of the plane.
* @param[in] pVirtAddr mem mapped Virtual Addres pointer of the plane.
int NvBufferMemUnMap (int dmabuf_fd, unsigned int plane, void **pVirtAddr);
Certain APIs in nvbuf_utils.h have to be called in pair. Please take a look at the header file.
