cuGraphicsEGLUnRegisterResource failed: 709,400
I’m running my code following the sample. My code is simply a loop that constantly pulling image from camera and convert that NvBuffer to CUEglFrame. I’m also following the sample to unresigter pResource every time when I finished using the EglFrame. This code runs perfectly when started but usually after 10-15 mins, it will throw this error above. Then the system will send a segmentation fault error which will crash my app. I have tried multiple times and this seems to be a consistent behavior. I also monitored the memory usage and there is no memory leak. Before crash the memory is the same as when it began. I want to know what can be the possible reason that can cause this? i searched the meaning of the error code but I don’t understand why
Not sure but it is likely your CUDA code accesses the data outside the buffer, triggering memory corruption. Suggest you replace the code with Handle_EGLImage() in
/usr/src/jetson_multimedia_api/samples/common/algorithm/cuda/NvCudaProc.cpp
And check if the issue is still present.
I’m indeed copying this file
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
