A tractor driver is trying to fix AI again
They say:
βA nuclear physicist can become a painter, but a painter will probably never become a nuclear physicist.β
Wellβ¦
I am a tractor driver by profession. π
But apparently, if you stare at a problem long enough and are not afraid to ask stupid questions, sometimes you can make people from completely different professions a little nervous.
So:
Iβm bringing the fire β hold on to your cigars. π₯
There is one thing that has seriously started to piss me off.
I am building my own artificial intelligence architecture, but at the same time I constantly use ChatGPT, Claude, and Kimi β and again and again I run into exactly the same problem:
AMNESIA. π€¦π½ββοΈ
We can spend hours, days, months building a complex line of thought.
Making decisions.
Making mistakes.
Going back.
Finding the cause of a mistake.
Creating a new hypothesis.
Rejecting it.
Returning to an old subject a year laterβ¦
And suddenly the system behaves as if a significant part of that history never existed.
So I asked a very simple question:
Why should AI carry its entire life inside the context window at all?
Maybe the problem is not that the context window is too small.
Maybe the very idea of memory as one enormous active context window is wrong.
I am sharing part of my own AI architecture:
LACA + V-PACK + GHOST π» + UROBOROS
The idea is simple.
A conversation may last:
a day,
a year,
ten years,
an entire lifetime.
But the AI should not have to reread its entire life before every response.
It should have:
Yesterday β what actually happened;
Today / Uroboros β a small active working state;
Tomorrow / Future Scout β possible future directions, but not truth yet;
Scar β mistakes that must not simply be forgotten;
Ghost π» β old memory that is not currently materialized, but has not disappeared;
V-PACK β the structure in which this memory can live;
LACA β the mechanism that decides which part of the past should wake up now.
So not:
1,000,000 messages
β
put 1,000,000 messages into context
β
read everything again
but:
LIFELONG MEMORY
β
V-PACK / LACA
β
relevant branch
β
Ghost wake-up π»
β
exact old causal chain
β
small ACTIVE CONTEXT
β
new response
I HAVE ALREADY RUN THIS.
The test:
1,000,000 messages.
100,000 episodes.
Active Uroboros:
343 messages.
And then I went further.
I connected a real trained autoregressive Transformer, so that old memory would change not just some internal ACTION_3, but the actual text generated by a neural network.
The result:
500/500 memory-conditioned generations were exact in the controlled task.
Full-history and LACA produced:
100/100 identical memory descriptors
and
100/100 identical generated responses.
Now the interesting part.
I created two completely identical current worlds.
The same question.
The same current state.
The same Future Scout.
Only one thing was different:
in the first world, an old failure β a Scar β existed.
In the second world, I removed only that old Scar.
And I obtained:
100 cases where old memory alone changed the text generated now.
In other words:
CURRENT INPUT = SAME
but
OLD MEMORY A
β
RESPONSE A
OLD MEMORY B
β
RESPONSE B
This is no longer just a βchat archive.β
The past actually participates in present reasoning.
When a Scar blocks a future decision, the system does not pull in one million messages.
The Ghost wakes up and materializes one specific old causal episode.
In the test, this happened 238 times.
And I deliberately checked very old memory.
The oldest successfully verified event was:
999,990 messages ago.
It was still precisely addressable.
Its causal chain was reconstructed.
Integrity verification passed.
And now the number I particularly like.
To work directly with the full history:
β2.48 MiB of episode metadata active
With LACA:
218 B of active branch state
If an exact old causal chain is needed:
508 B
At the same time, the complete exact history does not disappear.
It remains in cold persistent storage.
So I am not magically compressing one million messages into 218 bytes.
I am doing something else:
I AM NOT DRAGGING ONE MILLION MESSAGES INTO A PLACE WHERE, AT THIS MOMENT, ONLY 218 BYTES OF STATE ARE NEEDED.
That is a very different thing.
So maybe the wrong question is:
βWhen will LLMs have a context window of one billion tokens?β
A better question might be:
WHY DOES AN AI NEED ONE BILLION TOKENS OF ACTIVE CONTEXT AT ALL?
Maybe AI does not need an infinite context window.
Maybe it needs:
AN UNLIMITED HISTORY + A FINITE ACTIVE MIND.
Lifelong memory.
Small active state.
Exact selective recall.
Scars.
Causality.
Provenance.
Ghost.
And a future that does not yet have the right to call itself truth.
I am publishing this not because I think the work is finished.
Quite the opposite.
There is still a hell of a lot of work left.
This is still a controlled synthetic task.
The model is small.
This is not yet a general-purpose LLM.
This is not yet a hardware benchmark.
But the mechanism already works.
And I am tired of watching AI systems become larger and larger, only to forget what we were talking about yesterday. π€¦π½ββοΈ
So here you go β part of the memory architecture from my own AI.
Maybe now youβll finally start moving. π€¬π₯³
And, as always:
donβt believe the tractor driver.
Everything is in the archive.
Code.
Model.
Tests.
Counterfactual cases.
Exact ancient-memory recall.
Training curve.
CSV files.
Report.
SHA-256.
VERIFY IT.
LACA_VPACK_NEURAL_LIFELONG_DIALOGUE_BENCHMARK_V3-1.zip (396.7 KB)
