Unsigned DPA program on CX7
I’m working with a NVIDIA ConnectX-7 MCX755106AS-HEA_Ax (PSID MT_0000000834) with firmware 28.44.1036.
I’m developing DPA applications using DOCA, but I currently don’t have access to NVIDIA Enterprise / the NVIDIA signing infrastructure, so I cannot get my DPA application signed on the CX7, where the BF3 allows un-signed DPA app.
I would therefore like to know whether it is possible to disable DPA application authentication on this ConnectX-7, so that I can load and execute unsigned DPA applications for development.
Some details:
  • ConnectX-7, MCX755106AS-HEA_Ax
  • 200GbE / NDR200, dual QSFP112
  • Firmware: 28.44.1036
  • PSID: MT_0000000834
  • Security Attributes: secure-fw
  • Secure Boot: enabled
Interestingly, mlxconfig show_confs reports:
DPA AUTH:
    DPA_AUTHENTICATION=<False|True>
        When TRUE, DPA code is authenticated before executed.
However, mlxconfig ... q does not show DPA_AUTHENTICATION, and querying it explicitly does not work either.
I also generated the device TLV list, which contains:
nv_dpa_auth
nv_dpa_app_0
nv_dpa_app_7
nv_dpa_partition_0
nv_dpa_partition_7
My questions are:
  1. Can DPA authentication be disabled on this card?
  2. If it is currently enabled, can it be disabled without NVIDIA Enterprise signing access?
  3. Does disabling NIC secure firmware / Secure Boot have any relation to DPA application authentication, or are these completely separate mechanisms? And if so can I do it?
  4. Is there a particular firmware version or MFT version that supports unsigned DPA development on this CX7?
Hi @tom.barbette,
Thank you for posting your query.
From the DOCA documentation, DPA application authentication is controlled separately from NIC secure firmware and platform Secure Boot. Disabling secure firmware or Secure Boot is not a supported method for bypassing DPA application authentication.
DPA authentication is also not exposed as a simple user toggle. Enabling or disabling it is part of the signed device ownership / NVconfig flow, and the relevant TLV update is itself authenticated. For first-time enablement, NVIDIA Enterprise Support involvement is required.
Based on this, we do not see a supported public method to disable DPA authentication on a secure-fw ConnectX-7 through mlxconfig / MFT alone. We also do not have a documented public FW / MFT combination for unsigned DPA development on this CX7 platform.
For reference:
If further troubleshooting assistance is needed, a valid support entitlement for the HCA is required.
If you have an active support contract, please log in to the NVIDIA Enterprise Support
Portal and open a new support case. For questions about support coverage, contact Networking-Contracts@nvidia.com.
Thank you,
NVEX Networking Technical Support Team
Thank you very much for your answer @mamatham. We have contracts for other NICs, but not that one. Is there a way to check first if a support contract actually allow to open it?
Thanks,
Tom
