ConnectX-7: format_select_dw_8_6_ext = 0 — blocks DOCA Flow IPv6 CT pipe
We are building a commercial IaaS+PaaS cloud SDN data plane using DOCA Flow
on ConnectX-7. We need IPv6 Connection Tracking which requires the
format_select_dw_8_6_ext (full_dw_jumbo_support) capability bit.
We have tested three different SKUs:
  • MCX75310AAS-NEA (PSID MT_0000000838, 400G NDR OSFP)
  • MCX713106AS-VEA (PSID MT_0000000840, 200G QSFP112)
  • MCX755206AS-NEA (PSID MT_0000000892, DGX storage)
All three: format_select_dw_8_6_ext = 0 in BOTH GET_CUR and GET_MAX
on firmware 28.48.1000 (latest).
Steps we have already verified:
  1. No mlxconfig variable affects this bit (tested 24 NV-config changes
    with mlxfwreset, all confirmed via -e -a query showing Current column).
  2. CR-space direct access returns 0xbadacce6 (blocked on standalone CX-7).
  3. SET_HCA_CAP from userspace is filtered by kernel mlx5 driver (EINVAL).
  4. All public CX-7 PSIDs share identical MAIN_CODE section.
Questions:
  1. Is there a roadmap to enable IPv6 CT pipe on standalone ConnectX-7?
  2. Is there a documented mechanism (signed CS/CRCS/DBG token) to unlock
    this capability for evaluation/research?
  3. The DOCA Flow CT documentation states “BlueField-3 and above required
    for IPv6”. Is this a permanent product positioning decision or
    firmware/HW limitation?
We are happy to share our CRCS challenge tokens with NVIDIA Engineering
support team. We have an active deployment of 3+ CX-7-based SDN nodes
and would prefer not to migrate to BlueField-3 if there is a path forward.
Thank you for your questions.
In order to answer them, opening a new support case will be required.
To Create a New Enterprise Support Case Please Use One of the Following Methods
1. Log in and Create a Case in the Enterprise Support Portal
This is recommended and will provide the fastest response
2. Call your Regional Enterprise Support Number
Find your regional phone numbers:
https://www.nvidia.com/en-eu/support/enterprise/#contact-us
3. Create a Case Without a Login
Can be used to check warranty status
Recommended to reset login passwords
Requires validation and may increase time to respond
Best Regards,
Anatoly
