OVS-DOCA on CX-7 LAG: offloaded Geneve flows hit in HW but all packets punted to PMD
Product / Severity
  • Product: DOCA-OVS (OVS-DOCA), ConnectX-7
  • Severity: High (hardware offload non-functional for the entire deployment role)
Environment
Item Value
NIC ConnectX-7, MCX755106AS-HEA_Ax, PSID MT_0000000834
Firmware 28.47.2682
DOCA doca-host 3.3.0109 (RELEASE 26.01-based-3.3.6)
OVS ovs-vswitchd (Open vSwitch) 3.3.0040, datapath_type=doca, DPDK 25.11.0+doca2601
OS / kernel Rocky Linux 9.7, kernel 5.14.0-611.55.1.el9_7.x86_64
Bonding Two CX7 ports (38:00.0 / 38:00.1) in kernel LACP bond (mode 802.3ad), eswitch switchdev, hardware LAG; OVS port bond0 is type=doca attached to the bond
Topology OpenStack/OVN gateway node. All traffic is wire-to-wire hairpin on the same LAG: RX on VLAN 81 (external) → route → Geneve encap (with one OVN TLV option, class=0x102, type=0x80, 4-byte data) → push VLAN 71 (underlay) → TX out the same bond. Reverse direction: Geneve+option decap → push VLAN 81 → TX same bond
other_config doca-init=true, hw-offload=true, pmd-cpu-mask=0xf0 (4 PMDs), vlan-limit=0
FLEX_PARSER_PROFILE_ENABLE reproduced with both 0 and 8 (cold reboot between)
Problem statement
For a plain routed flow with no conntrack and no NAT (single flat megaflow:
pop_vlan → set_mac → dec_ttl → tnl_push(geneve+option) → push_vlan → output),
OVS reports the flow as fully offloaded (offloaded:yes, dp:doca), and
ovs-appctl doca/dump-offloads shows a complete HW rule including the
62-byte precompiled raw_encap header and the final forward action.
However, every single data packet still arrives at the PMD. Packet captures
via ovs-appctl dpif-doca/dump-packets on show that each packet reaching the
PMD is wrapped in an internal VXLAN encapsulation with VNI=0xdead, carries
non-zero flow metadata written by the HW pipeline (e.g. meta=0x00002000), and
is immediately logged as post-hw-recover by netdev_offload_doca. I.e. the
packet hit the HW rules (metadata is set), but HW did not complete
forwarding and punted it to SW, which then executes the full action list
(~1000–1100 cycles/packet measured).
Effective result: OVS-DOCA on this node behaves as software forwarding for
100% of traffic. Throughput is identical to a kernel-OVS gateway on the same
path (~17.3 Gbps, limited elsewhere), with roughly 2x more TCP retransmissions
in the encap direction.
Evidence
1. HW rule is complete (doca/dump-offloads, offload-trace enabled)
flow create 0 user_id ... priority 1 group 0x0 transfer
  pattern port_id id is 0 physdev=1 / tag index 3 spec 0x0 /
          eth src is 72:3a:c0:51:04:65 dst is fa:16:3e:04:af:83 type is 0x8100 has_vlan is 1 /
          vlan inner_type 0x800 tci spec 0x51 tci mask 0xefff /
          ipv4 src spec 10.199.81.245 mask /30 dst is 192.168.150.243 proto 6 ttl is 0x40 / tcp
  actions count / of_pop_vlan / set_mac_src fa:16:3e:74:03:65 / set_mac_dst fa:16:3e:92:13:43 /
          set_ipv4_ttl 63 / raw_encap index 0 (62B: eth+ipv4+udp(6081)+geneve(vni,1 TLV opt)+...) /
          represented_port ethdev_port_id 0
Reverse (decap) rule equally complete: geneve+geneve-opt match → raw_decap →
of_push_vlan(81) → represented_port 0.
2. Every packet is punted via VNI=0xdead and recovered in SW
dpif_doca(pmd-c05)|INFO|port_no=3: in_port=3, recirc_id=0, meta=0x00002000, size=1568.
  outer: eth(zeros)/ipv4(src=0.0.0.0,dst=0.0.0.0,ttl=0)/udp(dst=4789)/vxlan(VNI=0xdead)
  inner: original frame (VLAN 81, 10.199.81.245 -> 192.168.150.243, TCP 5201), 1518B
dpif_doca(pmd-c05)|INFO|post-hw-recover: port_no=3: ... size=1518. (original frame)
~450k post-hw-recover log lines accumulate per few minutes of a single
iperf3 stream. Both encap and decap directions punt.
3. PMD perf counters — HW classification works, forwarding does not
During a 60 s single-stream run (dpif-doca/pmd-perf-show, core carrying the flow):
Rx packets:      51,328,414   (989 cycles/pkt)
Datapath passes: 51,328,744   (1.00/pkt)
- PHWOL hits:    0
- EMC hits:      16,662  (0.0%)
- Megaflow hits: 2,538,597 (4.9%)
  -> ~95% of packets resolved via HW flow mark (skip SW classifier)
Tx packets:      24,365       (TX side completed without PMD Tx involvement)
4. Also reproduced / already ruled out
  • FLEX_PARSER_PROFILE_ENABLE 0 and 8 (cold reboot): identical punt behavior.
  • Not CT-related: the flat flow above has no ct() at all. (Separately, OVN FIP
    NAT chains — ct(zone13,nat)→ct(commit,zone14,nat)→ct(zone13,nat) — never get
    HW CT connections, consistent with documented CT-CT-NAT unsupported.)
  • Not check_pkt_len-related: OVN gateway_mtu was removed for the test
    router, the megaflow contains no check_pkt_len, and the rule does get
    inserted into HW — insertion is not the problem, execution is.
  • Rules are hit: punted packets carry HW-written metadata (meta=0x2000/0x3000),
    which a HW-miss packet would not have.
  • Port capabilities report tx_geneve_tso_offload=false,
    tx_out_ip_csum_offload=true, tx_out_udp_csum_offload=false.
Questions
  1. Is wire-to-wire (hairpin) forwarding with raw_encap/raw_decap of
    Geneve (carrying one TLV option) expected to be executed fully in eswitch
    HW on ConnectX-7 in OVS-DOCA 3.3, when the underlying port is a kernel
    LACP bond (hardware LAG) and both inner directions involve VLAN
    push/pop on the wire side?
  2. What exactly does the VNI=0xdead recovery path indicate — which action in
    our rule fails HW execution and triggers the punt? Is there a counter or
    debug knob that reports the punt reason?
  3. Is this a known limitation or a known issue in DOCA 3.3.0109
    (possibly related to Issue 4943253)? Is it fixed in DOCA 3.4 or later?
  4. If this combination (LAG + VLAN underlay + Geneve w/ TLV option + hairpin)
    is outside the supported offload matrix for gateway-style nodes, please
    point us to the authoritative support matrix statement.
Attachments (available on request)
  • Full ovs-appctl doca/dump-offloads output (offload-trace enabled)
  • ovs-vswitchd.log segment with dump-packets + post-hw-recover entries
  • ovs-appctl dpif-doca/pmd-perf-show full output for all 4 PMDs
  • ovs-vsctl show, ovs-vsctl list Open_vSwitch, bond/interface configs
  • mlxconfig -d 38:00.0 q full query, mlxfwmanager --query
  • OVN NB/SB relevant logical router / LRP configuration
help me for this question。
The docs state that OVS-DOCA supports LACP bond mode, hairpin “wire to wire” forwarding, multiport eSwitch forwarding between physical ports, and Geneve offload with extension-header matching and one Geneve option. However there is no published support matrix for combination of these features. Based on the observed behavior, the recovery path indicates that hardware classification/offload processing was engaged, but the packet was recovered to software before completion of the intended forwarding path. The 0xdead path indicates HW recovery to software, public docs do not expose a reason-specific punt counter, and we do not currently have a public known-issue or fix note that conclusively explains or resolves this exact case.
Please open a support case to track this question, since the test scenario involves multiple components working together which requires further tests/validation.
