Hi Team,
I am using CX7 card in switchdev mode with OVS for Data path offloading for ROCE testing.
We are using VLAN + PCP is set to 3 for the packets coming out of VM.
ahv6 is the representor for the VF which is assigned to VM and eth3 is the uplink port.
As ROCE need loss less ethernet so we want to use PCP bit in the VLAN for flow control so used mlx_qos for the config. I am not able to see the packets in prio3 queue. Any thing I am missing. Please help on this query.
>> OVS flow which is offloaded to eswitch
ufid:e5e38cda-0d1d-4064-b4ee-ca3af28c0c79, recirc_id(0),dp_hash(0/0),skb_priority(0/0),in_port(ahv6),skb_mark(0/0),ct_state(0/0),ct_zone(0/0),ct_mark(0/0),ct_label(0/0),packet_type(ns=0/0,id=0/0),eth(src=50:6b:8d:77:ec:c2,dst=50:6b:8d:52:cd:9b),eth_type(0x0800),ipv4(src=0.0.0.0/0.0.0.0,dst=0.0.0.0/0.0.0.0,proto=17,tos=0/0,ttl=0/0,frag=no),udp(src=0/0,dst=4791), packets:10009, bytes:5865274, used:1.920s, offloaded:yes, dp:tc, actions:push_vlan(vid=222,pcp=3),eth3
$mlnx_qos -i eth3
DCBX mode: OS controlled
Priority trust state: pcp
default priority:
Receive buffer size (bytes): 20016,156096,0,0,0,0,0,0,max_buffer_size=1027728
Cable len: 7
PFC configuration:
priority 0 1 2 3 4 5 6 7
enabled 0 0 0 1 0 0 0 0
buffer 0 0 0 1 0 0 0 0
tc: 0 ratelimit: unlimited, tsa: vendor
priority: 1
tc: 1 ratelimit: unlimited, tsa: vendor
priority: 0
tc: 2 ratelimit: unlimited, tsa: vendor
priority: 2
tc: 3 ratelimit: unlimited, tsa: vendor
priority: 3
tc: 4 ratelimit: unlimited, tsa: vendor
priority: 4
tc: 5 ratelimit: unlimited, tsa: vendor
priority: 5
tc: 6 ratelimit: unlimited, tsa: vendor
priority: 6
tc: 7 ratelimit: unlimited, tsa: vendor
priority: 7
$ ethtool -S eth3 | grep prio3
rx_prio3_bytes: 28470
rx_prio3_packets: 405
rx_prio3_discards: 0
tx_prio3_bytes: 456602
tx_prio3_packets: 773
rx_prio3_pause: 0
rx_prio3_pause_duration: 0
tx_prio3_pause: 12
tx_prio3_pause_duration: 6
rx_prio3_pause_transition: 0
rx_prio3_buf_discard: 0
rx_prio3_cong_discard: 0
rx_prio3_marked: 0
