Unsupported operation while compiling atomicMin
Hi everyone,
I am getting this error message “Error: unsupported operation” while trying to compile this piece of code :
int a = 20;
int b = 30;
atomicMin(&b, a-3);//the log trace points out to this line
The official doc states clearly that CUDA supports :
int atomicMin(int* address, int val);
I would like also to stress that I am using this code snippet within the body of a kernel. Is that the reason why I am getting this “Unsupported operation” error? If so how can I circumvent this problem (Id o need to calculate the min of two integers within the kernel since I am unable to make a host call for std::min from the device)?
Could anyone please point me to the error source here? Thank you.
An atomic operation must be done either on global or shared memory.
https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#atomic-functions
(read the first sentence)
This:
int b = 30;
is neither. It is in the local memory space. Atomics are unsupported on local memory.
You don’t need atomics to calculate things when using only a single thread. The nature of local memory usage is that it is visible only to a single thread. To find the minimum of two values in local memory associated with a particular thread, CUDA provides suitable functions for you.
It should be sufficient to do:
int a = 20;
int b = 30;
b = min(b, a-3);
@Robert_Crovella : Thank you!
