The default baudrate on /dev/ttyTHS1 and THS2 is 9600, is there anyway to update the UART port to higher baudrate, say 921600 and enable flow control as well?
C functions of “cfsetspeed” & “tcsetattr” seem to work to update the baudrate, though I haven’t figured out how to change the default baudrate during system boot.
Hi TKAI, does adding a line to /etc/rc.local to set the baudrate not work?
The instructions here describe the process: [ubuntu] setup startup scripts in /etc/rc.local
It may work. However there should be nicer way to update the default baud rate instead of calling a ‘C’ code.
