Hi! I ran the USB SDD upgrade as per the Jetson Hacks instructions. All is well and good until I try to update the DTB via jetson-io to use hardware pwm and it doesn’t ever get updated. Prior to an SSD upgrade I’ve gotten this to work.
I read here that:
Creates a new DTB or Device Tree overlay (DTBO) for the list of functions provided. If the command creates a new DTB file, the Linux boot configuration file (/boot/extlinux/extlinux.conf) is updated with a new option to boot using this DTB.
These are the contents of my extlinux.conf (Scroll down in text):
TIMEOUT 30
DEFAULT JetsonIO
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
# sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
# MENU LABEL backup kernel
# LINUX /boot/Image.backup
# INITRD /boot/initrd
# APPEND ${cbootargs}
LABEL JetsonIO
MENU LABEL Custom 40-pin Header Config
LINUX /boot/Image
FDT /boot/tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb
INITRD /boot/initrd
APPEND ${cbootargs}
