URDF exporter error
I receive an error when I try to export pretty big usd file of the robot:
2023-11-07 13:04:40 [2,163,657ms] [Error] [omni.kit.app._impl] [py stderr]: [WARNING] [TransformGraph.1] - Prim '/Root/_1020000_211_AP214_clean/Geometry/_1020000_211_AP214_trial11_from_PARASOLID_0/_1020002_Movable__2704/_1019634_Movable__3576/_1019703_Movable__4078/_1019962_Movable__4254/_1019639_4305/Imported1_4306/SICK_TiM781' (type: 'Camera') not added to `TransformGraph` because it is not a link type or a joint type prim.
2023-11-07 13:04:40 [2,163,667ms] [Error] [omni.ui.python] KeyError: ('/Root/_1020000_211_AP214_clean/Geometry/_1020000_211_AP214_trial11_from_PARASOLID_0/_1020002_Movable__2704/_1019634_Movable__3576/_1019703_Movable__4078/_1019962_Movable__4254/_1019639_4305/Imported1_4306/SICK_TiM781',)
At:
  /home/karavaev/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(686): _update_link_node
  /home/karavaev/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(585): _build_transform_graph
  /home/karavaev/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(286): init_from_stage
  /home/karavaev/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/to_urdf.py(70): __init__
  /home/karavaev/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/to_urdf.py(126): init_from_file
  /home/karavaev/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.exporter.urdf/omni/exporter/urdf/ui_builder.py(195): _on_export_button_clicked_fn
  /home/karavaev/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.ui/omni/isaac/ui/element_wrappers/ui_widget_wrappers.py(854): _on_clicked_fn_wrapper
Unfortunately, I cannot share the model, since it’s under NDA. What can I do to debug it?
@karavaev per the log alone, it appears there’s a Camera prim in the file. is it possible for you to navigate through your file and see if that’s the case?
if it is found, try removing it before exporting again?
Removed it and now exporter just basically got stuck after I hit export button, nothing happens for 10 mins already and Isaac Sim is not responsive.
Console log
[137.585s] [ext: omni.exporter.urdf-0.1.1] startup
you did say it’s a big file, how big is it?
It’s 150 MB
just out of curiosity, which version of Isaac Sim are you using?
It’s 2023.1
@karavaev please try waiting while the asset gets converted to USD? bigger assets take more time to get parsed
