URDF Export Error: "Joint transforms are not consistent"
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Topic Description
Hi all,
I’m encountering a URDF export error in Isaac Sim when trying to export a hand model. The error message says the joint transforms of right_wrist are not consistent.
Error Messages
2025-05-26 00:42:38 [1,278,323ms] [Error] [omni.ui.python] ValueError: The ‘right_wrist’'s joint transforms are not consistent.
global___joint_via_parent:
[[ 0.99991778 -0.00107529 0.01277769 0.01262659]
[ 0.00121027 0.9999435 -0.01056059 -0.00192864]
[-0.01276562 0.01057519 0.99986259 0.15084681]
[ 0. 0. 0. 1. ]]
global___joint_via_child:
[[ 0.99991778 -0.00167431 0.01271308 0.01262657]
[ 0.00121028 0.99933581 0.03642067 -0.00192864]
[-0.01276562 -0.03640229 0.99925568 0.15084675]
[ 0. 0. 0. 1. ]]
At:
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(816): _update_joint_node
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(686): _build_transform_graph
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(340): init_from_stage
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/to_urdf.py(74): init
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/isaacsim/exts/isaacsim.asset.exporter.urdf/isaacsim/asset/exporter/urdf/ui_builder.py(267): _on_export_button_clicked_fn
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/isaacsim/exts/isaacsim.gui.components/isaacsim/gui/components/element_wrappers/ui_widget_wrappers.py(886): _on_clicked_fn_wrapper
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/omni/kit_app.py(128): update
/home/tao/miniconda3/envs/isaaclab45/lib/python3.10/site-packages/isaacsim/init.py(163): main
/home/tao/miniconda3/envs/isaaclab45/bin/isaacsim(8):
Additional Context
hand14.usd.zip (1.4 MB)
I saw similar error message with a different joint:
2025-06-02 22:07:38 [57,892,691ms] [Error] [omni.ui.python] ValueError: The 'right_index_abd''s joint transforms are not consistent.
[[-0.41460916  0.90705789  0.07311108 -0.01209444]
 [-0.00251902 -0.08148557  0.99667134 -0.00988924]
 [ 0.9099961   0.41304489  0.03606956  0.21462987]
 [ 0.          0.          0.          1.        ]]
[[-0.41186366  0.90830784  0.07311079 -0.01209442]
 [-0.00276544 -0.08147724  0.99667137 -0.00988923]
 [ 0.91124129  0.41029053  0.03606939  0.21462987]
 [ 0.          0.          0.          1.        ]]
At:
  /home/vyu/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(816): _update_joint_node
  /home/vyu/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(686): _build_transform_graph
  /home/vyu/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/transform_graph.py(340): init_from_stage
  /home/vyu/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/to_urdf.py(74): __init__
  /home/vyu/isaacsim/exts/isaacsim.asset.exporter.urdf/pip_prebundle/nvidia/srl/from_usd/to_urdf.py(129): init_from_file
  /home/vyu/isaacsim/exts/isaacsim.asset.exporter.urdf/isaacsim/asset/exporter/urdf/ui_builder.py(270): _on_export_button_clicked_fn
  /home/vyu/isaacsim/exts/isaacsim.gui.components/isaacsim/gui/components/element_wrappers/ui_widget_wrappers.py(886): _on_clicked_fn_wrapper
This issue is often related to how the joints are defined in the original .usd file, especially if the relative transforms between connected bodies are not set up correctly. Please check the joint origins in your .usd file and ensure that the transforms for each joint are consistent and correctly positioned relative to the connected bodies.
Hello!
Best regards,
