Hi!
I’m trying to load the following urdf file (with the corresponding meshes in the seprate folder). I’ve adapted the file from urdf/Tutorials/Building a Visual Robot Model with URDF from Scratch - ROS Wiki a bit
<robot name="ROBOT">
<material name="blue">
<color rgba="0 0 0.8 1"/>
</material>
<material name="black">
<color rgba="0 0 0 1"/>
</material>
<material name="white">
<color rgba="1 1 1 1"/>
</material>
<link name="base_link">
<visual>
<geometry>
<cylinder length="0.6" radius="0.2"/>
</geometry>
<material name="blue"/>
</visual>
</link>
<link name="right_leg">
<visual>
<geometry>
<box size="0.6 0.1 0.2"/>
</geometry>
<origin rpy="0 1.57075 0" xyz="0 0 -0.3"/>
<material name="white"/>
</visual>
</link>
<joint name="base_to_right_leg" type="fixed">
<parent link="base_link"/>
<child link="right_leg"/>
<origin xyz="0 -0.22 0.25"/>
</joint>
<link name="right_base">
<visual>
<geometry>
<box size="0.4 0.1 0.1"/>
</geometry>
</visual>
</link>
<joint name="right_base_joint" type="fixed">
<parent link="right_leg"/>
<child link="right_base"/>
<origin xyz="0 0 -0.6"/>
</joint>
<link name="right_front_wheel">
<visual>
<origin rpy="1.57075 0 0" xyz="0 0 0"/>
<geometry>
<cylinder length="0.1" radius="0.035"/>
</geometry>
<material name="black"/>
<origin rpy="0 0 0" xyz="0 0 0"/>
</visual>
</link>
<joint name="right_front_wheel_joint" type="fixed">
<parent link="right_base"/>
<child link="right_front_wheel"/>
<origin rpy="0 0 0" xyz="0.133333333333 0 -0.085"/>
</joint>
<link name="right_back_wheel">
<visual>
<geometry>
</geometry>
</visual>
</link>
<joint name="right_back_wheel_joint" type="fixed">
<child link="right_back_wheel"/>
<origin rpy="0 0 0" xyz="-0.133333333333 0 -0.085"/>
</joint>
<link name="left_leg">
<visual>
<geometry>
</geometry>
</visual>
</link>
<joint name="base_to_left_leg" type="fixed">
<child link="left_leg"/>
<origin xyz="0 0.22 0.25"/>
</joint>
<link name="left_base">
<visual>
<geometry>
</geometry>
</visual>
</link>
<joint name="left_base_joint" type="fixed">
<parent link="left_leg"/>
<child link="left_base"/>
</joint>
<link name="left_front_wheel">
<visual>
<geometry>
</geometry>
</visual>
</link>
<joint name="left_front_wheel_joint" type="fixed">
<parent link="left_base"/>
<child link="left_front_wheel"/>
</joint>
<link name="left_back_wheel">
<visual>
<geometry>
</geometry>
</visual>
</link>
<joint name="left_back_wheel_joint" type="fixed">
<child link="left_back_wheel"/>
</joint>
<joint name="gripper_extension" type="fixed">
<child link="gripper_pole"/>
<origin rpy="0 0 0" xyz="0.19 0 0.2"/>
</joint>
<link name="gripper_pole">
<visual>
<geometry>
<cylinder length="0.2" radius="0.01"/>
</geometry>
<origin rpy="0 1.57075 0 " xyz="0.1 0 0"/>
</visual>
</link>
<joint name="left_gripper_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.2 0.01 0"/>
<parent link="gripper_pole"/>
<child link="left_gripper"/>
</joint>
<link name="left_gripper">
<visual>
<origin rpy="0.0 0 0" xyz="0 0 0"/>
<geometry>
<mesh filename="../meshes/l_finger.dae"/>
</geometry>
</visual>
</link>
<joint name="left_tip_joint" type="fixed">
<parent link="left_gripper"/>
<child link="left_tip"/>
</joint>
<link name="left_tip">
<visual>
<origin rpy="0.0 0 0" xyz="0.09137 0.00495 0"/>
<geometry>
<mesh filename="../meshes/l_finger_tip.dae"/>
</geometry>
</visual>
</link>
<joint name="right_gripper_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.2 -0.01 0"/>
<child link="right_gripper"/>
</joint>
<link name="right_gripper">
<visual>
<origin rpy="-3.1415 0 0" xyz="0 0 0"/>
<geometry>
</geometry>
</visual>
</link>
<joint name="right_tip_joint" type="fixed">
<parent link="right_gripper"/>
<child link="right_tip"/>
</joint>
<link name="right_tip">
<visual>
<origin rpy="-3.1415 0 0" xyz="0.09137 0.00495 0"/>
<geometry>
</geometry>
</visual>
</link>
<link name="head">
<visual>
<geometry>
<sphere radius="0.2"/>
</geometry>
</visual>
</link>
<joint name="head_swivel" type="fixed">
<child link="head"/>
<origin xyz="0 0 0.3"/>
</joint>
<link name="box">
<visual>
<geometry>
<box size="0.08 0.08 0.08"/>
</geometry>
</visual>
</link>
<joint name="tobox" type="fixed">
<parent link="head"/>
<child link="box"/>
<origin xyz="0.1814 0 0.1414"/>
</joint>
</robot>
But I do get the following Segmentation fault error from the running isaac sim container:
2020-10-16 11:35:44 [651,265ms] [Info] [omni.isaac.urdf] Trying to import /isaac-sim/_build/linux-x86_64/release/exts/omni.isaac.samples/omni/isaac/samples/scripts/urdf_examples/simple_robot/urdf/robot.urdf
[NvIsaac::Debug] Executable path: '/isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/omniverse-kit'
[NvIsaac::Debug] Found data directory '/isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data'
[NvIsaac::Debug] Asset search paths:
[NvIsaac::Debug] /isaac-sim
[NvIsaac::Debug] /isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data
[NvIsaac::Debug] /isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data/urdf
[NvIsaac::Debug] /isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data/IML
[NvIsaac::Debug] /isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data/cache
[NvIsaac::Debug] /isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data/commandscript
[NvIsaac::Debug] /isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data/meshes
[NvIsaac::Debug] /isaac-sim/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/data/TestData
**[NvIsaac::Info] Stream Importing robot from '/isaac-sim/_build/linux-x86_64/release/exts/omni.isModel ROBOT loaded!**
Fatal Python error: Segmentation fault
Current thread 0x00007f07e0f31740 (most recent call first):
File "/isaac-sim/_build/linux-x86_64/release/exts/omni.isaac.urdf/omni/isaac/urdf/scripts/extension.py", line 60 in _select_picked_folder_callback
/isaac-sim/_build/linux-x86_64/release/isaac-sim-headless.sh: line 4: 10 Segmentation fault (core dumped) "$SCRIPT_DIR/../../target-deps/kit_sdk_release/_build/linux-x86_64/release/omniverse-kit" --config-path "$SCRIPT_DIR//experiences/isaac-sim-headless.json" --no-window $@
and then the client also freezes of course.
I even get the error with a simple file like:
<robot name="myfirst">
<visual>
<geometry>
</geometry>
</visual>
</link>
</robot>
Any ideas?
