that’s the verbose output message after “Check successful” (I’m also adding a ground plane before loading the robot urdf):
2021-12-21 11:47:17 [173,908ms] [Info] [omni.usd] ResyncedPaths: /World/GroundPlane
2021-12-21 11:47:17 [173,912ms] [Info] [omni.usd] ResyncedPaths: /World/GroundPlane/CollisionMesh
2021-12-21 11:47:17 [173,916ms] [Info] [omni.usd] ResyncedPaths: /World/GroundPlane/CollisionPlane
2021-12-21 11:47:17 [173,917ms] [Info] [omni.usd] ResyncedPaths: /World/GroundPlane/CollisionPlane
2021-12-21 11:47:17 [173,993ms] [Info] [carb.python] Handle changed 3 prims for layer anon:0x12104f80:World0.usd.
2021-12-21 11:47:17 [173,993ms] [Info] [carb.python] Load prim spec tree rooted from /World/GroundPlane
2021-12-21 11:47:17 [173,993ms] [Info] [carb.python] Handle changed prims for layer anon:0x12104f80:World0.usd done.
2021-12-21 11:47:17 [174,052ms] [Info] [carb.settings.python] ISettings.get(...) was called on element that has no value (from python). Use set_default(...) before to set default value. (path = 'ext/omni.kit.widget.stage/exclusion/types')
turtlebot3_manipulation_robot.urdf /home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf2021-12-21 11:47:30 [187,249ms] [Info] [carb.python] [py stdout]: turtlebot3_manipulation_robot.urdf /home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf
2021-12-21 11:47:30 [187,249ms] [Info] [omni.isaac.urdf] Trying to import /home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf/turtlebot3_manipulation_robot.urdf
2021-12-21 11:47:30 [187,249ms] [Info] [omni.isaac.urdf] Loading URDF at '/home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf/turtlebot3_manipulation_robot.urdf'
2021-12-21 11:47:39 [196,152ms] [Info] [omni.isaac.urdf] Trying to import /home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf/turtlebot3_manipulation_robot.urdf
2021-12-21 11:47:39 [196,152ms] [Info] [omni.isaac.urdf] Loading URDF at '/home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf/turtlebot3_manipulation_robot.urdf'
2021-12-21 11:47:39 [196,154ms] [Info] [omni.usd] ResyncedPaths: /physicsScene
2021-12-21 11:47:39 [196,156ms] [Info] [omni.usd] ResyncedPaths: /physicsScene
2021-12-21 11:47:39 [196,161ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation
2021-12-21 11:47:39 [196,162ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation
2021-12-21 11:47:39 [196,164ms] [Info] [omni.usd] ResyncedPaths: /World
2021-12-21 11:47:39 [196,164ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation
2021-12-21 11:47:39 [196,164ms] [Info] [omni.isaac.urdf] Found base link called base_footprint
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_footprint has child base_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child link1
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child camera_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child caster_back_left_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child caster_back_right_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child imu_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child base_scan
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child wheel_left_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link base_link has child wheel_right_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link link1 has child link2
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link link2 has child link3
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link link3 has child link4
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link link4 has child link5
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link link5 has child end_effector_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link link5 has child gripper_link
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link link5 has child gripper_link_sub
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link camera_link has child camera_depth_frame
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link camera_link has child camera_rgb_frame
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link camera_depth_frame has child camera_depth_optical_frame
2021-12-21 11:47:39 [196,165ms] [Info] [omni.isaac.urdf] Link camera_rgb_frame has child camera_rgb_optical_frame
2021-12-21 11:47:39 [196,166ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks
2021-12-21 11:47:39 [196,166ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_black
2021-12-21 11:47:39 [196,167ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_black/Shader
2021-12-21 11:47:39 [196,170ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_blue
2021-12-21 11:47:39 [196,171ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_blue/Shader
2021-12-21 11:47:39 [196,174ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_brown
2021-12-21 11:47:39 [196,175ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_brown/Shader
2021-12-21 11:47:39 [196,178ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_dark
2021-12-21 11:47:39 [196,179ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_dark/Shader
2021-12-21 11:47:39 [196,182ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_green
2021-12-21 11:47:39 [196,183ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_green/Shader
2021-12-21 11:47:39 [196,186ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_grey
2021-12-21 11:47:39 [196,187ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_grey/Shader
2021-12-21 11:47:39 [196,190ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_light_black
2021-12-21 11:47:39 [196,191ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_light_black/Shader
2021-12-21 11:47:39 [196,194ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_orange
2021-12-21 11:47:39 [196,195ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_orange/Shader
2021-12-21 11:47:39 [196,198ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_red
2021-12-21 11:47:39 [196,199ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_red/Shader
2021-12-21 11:47:39 [196,202ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_white
2021-12-21 11:47:39 [196,203ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/Looks/material_white/Shader
2021-12-21 11:47:39 [196,205ms] [Info] [omni.isaac.urdf] Add Rigid Body: base_footprint
2021-12-21 11:47:39 [196,206ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/base_footprint
2021-12-21 11:47:39 [196,209ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/base_footprint
2021-12-21 11:47:39 [196,210ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/base_footprint
2021-12-21 11:47:39 [196,210ms] [Info] [omni.isaac.urdf] Add Rigid Body: base_link
2021-12-21 11:47:39 [196,210ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/base_link
2021-12-21 11:47:39 [196,213ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/base_link
2021-12-21 11:47:39 [196,214ms] [Info] [omni.usd] ResyncedPaths: /turtlebot3_manipulation/base_link
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/robolab/ros/catkin_ws/src/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/robolab/ros/catkin_ws/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/robolab/ros/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/robolab/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Info] [omni.isaac.urdf] trying '/home/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl' (0)
2021-12-21 11:47:39 [196,216ms] [Warning] [omni.isaac.urdf] Failed to resolve mesh 'package://turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl'
2021-12-21 11:47:39 [196,216ms] [Error] [omni.client.plugin] Main: usd_plugin: Used null prim
2021-12-21 11:47:39 [196,216ms] [Error] [omni.client.plugin] Main: usd_plugin: Fatal error in void pxrInternal_v0_20__pxrReserved__::Usd_IssueFatalPrimAccessError(const pxrInternal_v0_20__pxrReserved__::Usd_PrimData*)
the right path would be /home/robolab/ros/catkin_ws/src/turtlebot3/turtlebot3_description/meshes/bases/waffle_base_for_open_manipulator.stl. The problem might be that the robot definition is inside another package than the robot manipulator urdf loaded into isaac sim.
Reminder: the urdf loaded into isaac sim is at /home/robolab/ros/catkin_ws/src/turtlebot3_manipulation/turtlebot3_manipulation_description/urdf/turtlebot3_manipulation_robot.urdf
